Go Back   Music Electronics Forum > Amplification > Guitar Amps > Build Your Amp > Tweed Builders
Old 08-29-2009, 08:23 AM   #1
6V6's in Tweed Super
I've just tried some JJ6V6's in a tweed super clone. My plate voltage is 435V with a 5R4GYA rectifier, I've got 1K 2W screen resistors.
The JJ6V6 data sheet says the screens can handle 450V & the plates can handle 500V, but I want to be on the safe side.
Should I increase the value of these resistors to drop the screen voltage down more?
Thanks
Rob
RobBozic is offline   Reply With Quote
Old 08-30-2009, 02:56 AM   #2
Supporting Member
What is your plate dissipation? IMHO JJ6V6s in Class AB1 can handle those voltages if they are biased so that the dissipation is around 70-85% of 14W at idle - preferably on the lower side. (What do they look like when you fire them up?)
__________________
tubeswell is online now   Reply With Quote
Old 08-30-2009, 09:51 AM   #3
I've got them at 70%. Do you think I should bias them hotter so as to drop the voltage?
Rob
Old 08-31-2009, 09:24 PM   #4
Supporting Member
If that is what they are , they are running within spec. What do they sound like?
If you want lower volatges, why not try a 5y3G or zener down the B+?
__________________
Build 5E4-A (6v6 tweed super) with 5e3 transformers? lacrebob Tweed Builders 5 08-28-2009 05:17 PM
Tweed Super 5F4 output Impedance Question frances Tweed Builders 4 03-25-2009 04:22 AM
Tweed Super (5F4) rectfier alternatives... Cobra Tweed Builders 4 10-16-2007 06:40 AM
Tweed Super questions Mark Buckingham Theory & Design 4 05-09-2007 01:37 AM
FA: New Tweed Super 5F4 pine cabinet Bruce / Mission Amps Flea Market 1 08-29-2006 07:48 PM
