Go Back   Music Electronics Forum > Amplification > Other Amps
Old 08-29-2009, 10:39 AM   #1
SWR pro ser 900 distorted
Hi forum, I had a SWR 900 head come in with a bad power switch and a broken knob, a few were dirty also.
replaced the power switch, no issues.
The knob was a bass tone control. I used a simple panel mount with leads to replace it. seems fine.
When I reassembled the amp it now has a brief, 15 second, clip light at power up, not sure that's normal. I can't get the manual to download fromt he swr website.
My problem that is certain is that the amp seems to have huge gain and is distorted. Even with the gain down all the way the clip light will light and then the compressor. Plugging into the eff. ret. shows the PA is fine.
I figure I got some wires messed up since everything is soldered in place, I guess they've never heard of disconnects.
I'm hoping someone else has run into this problem during a rebuild.
It seems to come from the circuit around the gain pot as removing this opamp makes the biggest difference. removed the tube and all the rest of the opamps and the clip led still lights during startup. not so with IC2 as the schematic calls it.
UE
unclerny is offline   Reply With Quote
Old 08-29-2009, 09:40 PM   #2
Seems unlikely that someone else would make the exact same wiring problem. But maybe.
Are we talking SM 900? Here is the newer preamp. or is yours from 1997 or earlier?
File Type: pdf SM-900 Preamps A & B Plus power Supply.pdf (333.8 KB, 14 views)
__________________
Old 09-01-2009, 01:39 PM   #3
Thanks Enzo, I figured I'd give it a try. I'm at a loss as I don't have many reassembly problems. Pretty observant. I'm not sure what year but it is the SM900. I'll compare your schematic against it.
The owner has hauled it around unracked so it's aged a good bit and explains why several of the stacked pots are tweaked a bit but functional.
As before, I've pulled each of the opamps to track to a particular circuit and the only one that stops the over driven problem is the one right behind the gain pot, U2 I believe. All others seem to have no effect. I tried another tube also.
Old 09-01-2009, 01:43 PM   #4
Enzo, you're schematic appears the same and is better than the one I found.
Thank you, UE
Old 09-01-2009, 07:55 PM   #5
Enzo, this amp was built 11/27/97.
I don't know if this helps.
Tim
Old 09-02-2009, 01:51 AM   #6
It matches the schematic or it doesn;t, that is the test.
__________________
SWR Workingman's - distorted lowell Maintenance, Troubleshooting & Repair 28 09-30-2009 10:10 PM
Peavey Bass Amp Distorted Gnash Music Electronics 5 02-15-2009 01:20 PM
distorted g-k? mattbassplaya Maintenance, Troubleshooting & Repair 7 12-03-2008 04:15 AM
Traynor YGM3 distorted reverb lowell Maintenance, Troubleshooting & Repair 2 06-19-2008 10:29 PM
Loud and distorted London Customs Pickup Makers 8 02-08-2007 07:45 PM
