Go Back   Music Electronics Forum > Amplification > Guitar Amps > Build Your Amp
Old 09-03-2009, 01:12 PM   #1
Which fuse to use...???
What mains fuse rating should I use with a power transformer having the following specs:
Secondary: 300-0-300 V, 150 mA
Filament winding 1: 5 V, 3 A CT
Filament winding 2: 6.3 V, 5 A CT
Thanks for your help
acorkos is offline   Reply With Quote
Old 09-03-2009, 01:34 PM   #2
Supporting Member
300v x 150ma = 45va
6.3v x 5a = 31.5va
5v x 3a = 15va
91.5 va altogether
91.5va / 110v = 0.83a
Match to 1A and multiply by two = 2A mains fuse
or if you are on a 240VAC mains
(91.5va/240V = 0.38a) x 2 ~ 1A mains fuse
That PT is ideal for a 5G9 BTW. What were you planning to build?
__________________
Old 09-03-2009, 04:42 PM   #3
Quote:
5D4
Rectifier fuse? Axtman Theory & Design 3 06-11-2009 10:20 AM
Fuse popping... Colonel_Sanders Maintenance, Troubleshooting & Repair 3 06-09-2008 09:47 AM
fuse flows Salva Maintenance, Troubleshooting & Repair 4 06-03-2008 01:38 PM
B+ fuse killer Guitarist Maintenance, Troubleshooting & Repair 1 04-18-2008 06:40 AM
Marshall fuse value? drewl Maintenance, Troubleshooting & Repair 1 07-31-2007 11:41 PM
