Go Back   Music Electronics Forum > Amplification > Guitar Amps > Build Your Amp > Cabinetry
Old 09-04-2009, 09:08 AM   #1
txstrat's Avatar
Chassis mouting
Hi all,
I'm planning on building a 5F4 Super clone but don't have any information on the super cab except the outer measurements fromt the ampwares site.
Because I'm planning to build the cab by myself I need some information to mount the chassis to the cab.
Is the chassis held with only these two bolts from the upper side of the cab or are there any other (hidden) points to keep the chassis in place?
Any information would be greatly appreciated.
Thanks
Matt
txstrat is offline   Reply With Quote
Old 09-04-2009, 11:32 AM   #2
Supporting Member
Hi Matt
When I do my 'tweeds', I use four mounting bolts from the top, with a bit of rubber door weather seal stripping padding between the cab and the chassis to absorb vibrations. Keeps the chassis firmly in place.
__________________
Old 09-05-2009, 06:14 AM   #3
Tom Phillips's Avatar
The 5F4 Super like the tweed Bassman used three machine screws to hold the chassis to the cab. Attached is a photo of a 1958 Fender 5F4 Super chassis.
You can see two mounting at the ends of the chassis face and an angle bracket on the back of the power transformer for the third screw. The third screw gives good extra support to counteract the torque of the heavy PT.
Regards,
Tom
Tom Phillips is offline   Reply With Quote
Old 09-05-2009, 09:34 AM   #4
txstrat's Avatar
Great hint thanks.
There's no "head" of a third screw or bolt seen on the outside.
I'd guess the third screw would be driven in the wood from insiide the cabinet right?
Old 09-05-2009, 05:47 PM   #5
Matt,
The third screw head does show on the outside.
I've seen it left out during recover jobs and on some re-issue Fender amps. I suppose that Fender could have left it uninstalled on some original amps because they did make mistakes.
I recently restored a 1958 Bassman that had been covered in black Tolex. The third screw was left out and the pine cabinet cracked next to the remaining chassis screw on that side due to the added stress.
I'll look for more photos.
Regards,
Tom
Old 09-05-2009, 06:29 PM   #6
Matt,
Here is a photo of an old Super showing the third chassis screw head.
I’ve seen original Tweed Supers both with and without the third screw.
This is relevant if you want to build a faithful reproduction of the original. If you just want a clone for the sound then there are other ways to give the chassis / power transformer the support it needs. I think Mission Amps sells a larger angle bracket that fits the side of the chassis.
Regards,
Tom
Old 09-05-2009, 09:17 PM   #7
txstrat's Avatar
Tom
Woah, great, just what I was looking for. Thanks.
I don't think I'm gonna start a authentic copy since I believe my skills ar not good nough. But at least I want it to look like the original at first glance. Initially I had the idea to make the chassis broader and mount it to some brackets on the sides.
Now I think I'm gonna use a mix of the original way and tubeswell's proposal.
At time I'm still collecting parts and ideas. Gonna open a new thread when I start building, to keep you informed.
Thanks again guys.
Chassis? Cheap chassis? Satamax Guitar Amps 17 07-20-2009 09:29 AM
Chassis Layout defaced Theory & Design 5 04-29-2009 01:00 AM
55VAC on Chassis? chipaudette Other Amps 7 01-14-2009 03:59 PM
chassis on eBay RedHouse Build Your Amp 2 07-03-2007 02:23 PM
How Hot should the chassis get? zorro 5 E 3 7 06-30-2007 07:47 PM
