Go Back   Music Electronics Forum > Schematic Requests
Old 09-04-2009, 09:29 PM   #1
Crate Limo TX50D schematic
Does anybody have a schematic for a Crate Limo model TX50D. I have a broken one. I got a few bits and pieces from Loud Tech. I have the Pwr Supply, Mic Input Board, and DSP Board but no main board. Also the docs I have say TX50a. Loud said that was all they had and they lost a lot of stuff from the SLM archive. Thanks in advance.
-Feves
feves is offline   Reply With Quote
Old 09-05-2009, 04:37 AM   #2
The service disc is rather spotty on this.
Here is a more complete file on the TX50a, see if it helps. Just what part are you working on?
__________________
Old 09-05-2009, 05:30 AM   #3
The amp failed after the 15vdc wall wart was plugged into the 12vdc car adapter input. Amp would power up and make a few small pops and the LED would light brightly at first and then dim down to a faint glow. The amp would have no sound. I found that one of the opamps was bad when I tried it in a known good circuit. The others were fine. It was a 5534 that was bad. I didn't have another on hand so I replaced with TL082. Amp still does not work but now it oscillates when powered up. I suspect the power amp IC is bad as it's data sheet says it's max supply is 18vdc and the 15v wall wart puts out over 20vdc with no load. Thought I would check the schematic to see if it might be something else. Diodes on the main board look good.
Thanks for your help. Will post updates as I look into this one more tommorrow.
-Feves
Old 09-22-2009, 07:25 PM   #4
I pulled the power amp IC out and everything looks good the power LED changes from Red to Yellow instead of blinking red and I get signal on the scope all the way to the power amp IC pin 1. However, when I replaced the power amp IC it is still not working. Back to where it was. Any ideas?
I was VERY careful not to give it too much heat when I put it in.
The replacement is TDA1562QCD that I ordered from Digikey not sure the make.
The original is just TDA1562Q made by Phillips
Thanks,
feves
Need Crate CR60 schematic mnow Schematic Requests 1 08-13-2009 11:46 PM
Crate BV120H schematic please! walthur Schematic Requests 1 04-23-2009 12:58 AM
Schematic for a Crate FXT120 HarryB Schematic Requests 4 01-25-2009 06:13 PM
Crate schematic Valvehead Maintenance, Troubleshooting & Repair 1 12-18-2007 08:40 PM
Need schematic for Crate FXT120 fixitrightthefirsttime Maintenance, Troubleshooting & Repair 6 05-24-2007 02:57 AM
