Go Back   Music Electronics Forum > Amplification > Tubes (Valves)
Old 09-05-2009, 12:52 PM   #1
Hammond-labeled tubes - mfr?
Snagged a '68-'69 Hammond L-120 yesterday, and as I was vacuuming it out I pulled the tubes. All of them had Hammond labels, but most were marked Made in Gr Britain, and couple Made in Germany.
Anyone know who actually mfr'd these?
Also - the recto tube has this metal spring-looking thing stuck to the side of one of the elements. It may be touching the glass, it's so close to the side of the envelope. On inside of the glass around this thing there's a white crust - is that bad?
Thanks!
Don Moose is offline   Reply With Quote
Old 09-05-2009, 05:15 PM   #2
I have had several sets of Hammond labeled tubes. Most were Telefunken (look for the diamond on the base) or Mullard( look for the etching on the glass). In any case Hammond always used superior tubes , relabeled for them.
Hammond was/is the King of instruments.
billyz is offline   Reply With Quote
Old 09-05-2009, 06:43 PM   #3
But like most rebranders, it was not necessarily the same evey time. The 12AX7s could be one brand this season and another brand the next. SO you will have to ID the maker using clues such as billy provided or by posting photos for someone's visual ID.
__________________
Old 09-05-2009, 11:06 PM   #4
Old Tele man's Avatar
...most all of the OEM electronic equipment manufacturers -- like Hammond, Delco, Gibson, etc. -- did not make the tubes that went into their equipment, rather they ordered, special, re-labelled tubes, from whichever BIG tube manufacturer gave them the best price break. Hence, the HAMMOND 'name plate' label but the GB and Germany 'manufacturer' labels.
__________________
Old Tele man is offline   Reply With Quote
Old 09-06-2009, 02:37 AM   #5
I know a lot if not all Fischer and Dynaco tubes were relabeled Telefunken and Mullard or Amperex. I have many 12ax7's all Telefunken with those labels and more. My favorites are the Silvertone tubes that are actually Telefunken with the Diamond in the base.
Old 09-06-2009, 06:06 PM   #6
Here are some photos of a typical EL84 and 12AU7, and that 5U4 I'm worried about.
Old 09-06-2009, 06:44 PM   #7
Supporting Member
John_H's Avatar
Amperex?
John_H is offline   Reply With Quote
Old 09-06-2009, 08:50 PM   #8
They look like Philips and they ARE made in Holland.
unparalleled is offline   Reply With Quote
Old 09-06-2009, 10:09 PM   #9
Supporting Member
Steve Conner's Avatar
That 5U4 looks pretty much f****d to me. The white stuff means that air has got inside.
The "Made In Great Britain" tubes should be either Mullard or Brimar. Mullard would figure, since you can see the "Gf2" etching on your 12AU7.
Steve Conner is online now   Reply With Quote
Old 09-07-2009, 01:38 AM   #10
Quote:
Dirt.
Sweet!
Thanks guys!
Old 09-07-2009, 03:19 PM   #11
Alf
I think the 12ax7 is indeed a Philips from Eindhoven , where I live.
And here a better view maybe :
Alf
Alf is offline   Reply With Quote
Old 09-07-2009, 04:29 PM   #12
Quote:
The dead 5U4GB is GE production--you can tell by the 188 EIA code.
The white getter indicates loss of vacuum.
Hammond bought tubes from many different suppliers. I've primarily seen RCA and GE, though, as you can see, they did sometimes use European tubes, especially Amperex EL84s. I don't think I've ever found a Telefunken tube as a stock Hammond-labeled tube, but that doesn't mean it never happened.
Leslie, on the the other hand, had an affinity for Tung-Sol.
David
Rhodesplyr is offline   Reply With Quote
Old 09-07-2009, 05:43 PM   #13
Can the 5u4, I second what everyone else said about it.
here is a link of euro tube codes.
http://www.audiotubes.com/PhilipsCodeList.pdf
And Hammond did use Telefunken quite often.
smooth and ribbed plate.
GF2 is mullard or Loews opta after 54, F is June, can't make out the code on your el84.but you get the idea.
Old 09-08-2009, 07:17 PM   #14
Thanks, guys -
I had a 5u4 lying around, and it works!
Just gotta get the oil into all the places it's supposed to go and I'm good (so far).
Old 09-15-2009, 12:15 PM   #15
Lotta RCA in the Hammonds I've seen over the years.
Sweetfinger is offline   Reply With Quote
Old 10-03-2009, 10:04 AM   #16
Old hammonds are mostly RCA & GE.
Newer hammonds (that I've seen) are often mullard/eindhoven phillips/valvo?/GE 12ax7s.
Hammond often had service plans including tube replacement, so what we get might not be what they were shipped with.
6267 is offline   Reply With Quote
Old 10-15-2009, 05:10 AM   #17
My Hammond GZ34 is a Mullard.
RichardBM is offline   Reply With Quote
Old 10-15-2009, 04:29 PM   #18
Thanks, guys -
Mixing naptha with the Hammond oil (yes, use *real Hammond oil*, nothing else will work) is a good trick for cleaning up the oil wicks. The naptha will loosen up the gunk that is in the wicks and allow new oil to get to where it needs to be.
You can go about 50/50 mix. It'll still take a while....have patience.
__________________
Gtr_tech is offline   Reply With Quote
Hammond L-100 conversion Rafael Conversions 15 12-20-2009 07:02 PM
Hammond M-101 What have I got? Dave Johnson Conversions 2 12-20-2008 03:44 PM
Hammond tranny question Nalo1022 Music Electronics 5 11-06-2008 05:28 PM
Hammond 1750N...anyone used one daz Theory & Design 12 09-29-2008 09:23 AM
Hammond 125C for SE use? gmoon Theory & Design 3 03-09-2008 09:23 PM
