| | #1 |
| Senior Member Join Date: Nov 2008 Location: Norwalk CT
| I cut the trace between the lugs on the mids pot...
In my V32 I cut the trace that connects the middle and outside lug of the mid pot. The amp sounds punchier,livelier. I like it! Only problem is I dont know what Ive done really. Ive been told it makes the tonestack more like a Marshall? Anybody have any insight? The link is to the schematic.Thanks Bob http://www.schematicheaven.com/newam...2_palomino.pdf .....
__________________ "Reality is an illusion albeit a very persistant one " Albert Einstein |
| | #2 | |
| Member Join Date: Apr 2009
| Quote:
Edit: Needless to say, you've neutralized the mid control, now it's turned all the way to 10 all the time. | |
| | #3 | |
| Quote:
__________________ "Reality is an illusion albeit a very persistant one " Albert Einstein | |
| | #4 |
| Maybe it did in fact sound better, it's a god time as ever to measure resistance there between the wiper and the clockwise lead when it's fully turned right, it should be very near zero, in the fractions of ohms. If it isn't then you found a bad pot and your mod wasn't entirely lost work.
| | #5 | |
| Quote:
| | #6 |
Does this make sense? "unhook the leg of C11 that is connected to the trace running from P3 to P4 and jumper from that leg of C11 to the wiper of P3 while cutting the trace between the wiper and outer terminal of P3." Thanks Bob
| | #7 | |
| Quote:
It probably shouldn't be a difficult mod to try. This one would keep your mid control in the circuit, I'm just not sure what the frequency response will be afterwards. Let us know if you try! | |
| | #8 | |
| Quote:
Thanks. Im going to leave it. However R13 is the slope resistor and I bumped it up from 33 to 54K. Interesting slight shift the the tone controls/tone. I think a 100K pot and a 22K resistor would be very cool! Bob
| | #9 |
Switchable slope resistor added....76/33(stock)/54....Gettin crazy lookin in there! Bob
| | #10 |
| | #11 |
| Thanks. For v32 owners who might be interested. R45 controls the level of the "boost" feature. I removed the resistor and put a 100K pot in its place to make it variable. C53 dumps some of the highs in the boost so I made ir switchable R31 can be bridged to reduce the bass(which can get boomy stock) I put a switch across it to be able to switch it out(less bass). Basically a slight bass cut mod R13 is the slope resistor. I added two 22K's in series with the stock 33 and added a 3 way switch to each to make it 76,54 and 33K (stock) Also added a simple 120v fan with the push button switch. Bob
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Sivertone type amp...mids tweaks | tacoma98 | Mods & Tweeks | 12 | 09-25-2009 07:49 AM |
| Need Low-Cut Filter | booj | Music Electronics | 4 | 04-17-2009 06:10 PM |
| Amplifier cut outs | cisc | Maintenance, Troubleshooting & Repair | 10 | 08-30-2008 04:47 AM |
| Describe scooped mids | kevinT | Pickup Makers | 32 | 07-06-2007 01:12 PM |
| Cut control questions | Fred G. | Theory & Design | 8 | 01-17-2007 06:49 PM |
