Go Back   Music Electronics Forum > Instrumentation > Guitar Tech > Pickup Makers
Old 09-07-2009, 08:21 PM   #1
Strange pickup problem
Hello! I'm new into pickup making, hope you (experienced) guys will can shed light on this story...
I've built an humbucker and wired it in series with volume and tone pots (1M).
Series wiring should be the HOT of one bobin with the GROUND of the other one wired together, the other HOT on the + of the volume pot and the GROUND on the back of the pot. Well. It works but sounds a bit thin and is a bit noisy while, if I solder the HOT/GROUND wires for the series wiring on the back of the pot the hum goes down and the output goes up A LOT.
I've built the pickup with 2 single coils wound with 10mm alnico poles... one is South up and one is North up for hum cancelling. The controls routing is shielded with conductive varnish. Any idea? Thanx in advance!
Triad is offline   Reply With Quote
Old 09-07-2009, 08:55 PM   #2
It's not about linking "hot" of one bobbin to "ground" of another. How do you know which is hot or ground until they're in the circuit?
It should be about linking either start lead to start lead or finish lead to finish lead. Most makers do finish-to-finish, I'm a "maverick" in that I link start to start, but it works either way.
Zhangliqun is offline   Reply With Quote
Old 09-07-2009, 11:42 PM   #3
"Hot" is the start (white wire) and "Ground" is the end (black wire).
Old 09-08-2009, 12:59 AM   #4
Pickup Maker
David Schwab's Avatar
Your coils are out of phase.
The way to wire a humbucker is start to start, or finish to finish. So it's the "hot" of one coils to the "hot" on the other, not the ground!
The reason for this is each coil has the opposite magnetic polarity, so they are magnetically out of phase. So you have to wire them electrically out of phase to restore the phase of the coils, and then to cancel hum.
__________________
Those who create are rare; those who cannot are numerous. Therefore, the latter are stronger. - Coco Chanel
www.sgd-lutherie.com
www.myspace.com/sgdlutherie
www.myspace.com/davidschwab
David Schwab is online now   Reply With Quote
Old 09-08-2009, 02:08 AM   #5
Uhm... thanx for your reply, I'll check and get back in a few hours
Old 09-08-2009, 04:22 AM   #6
Yeah, what he said!
Old 09-08-2009, 07:28 AM   #7
One othr way to describe it (thanks goes out to Lollar) is "path to ground". If you ground the start wire from coil 1 you should have the end wire of coil 2 grounded trough coil 1. That way you have reversed the electric polarity of the two coils. Does that makes any sense? Probably not. Get Lollars book. He describes it better...
Has he released it as a E-book as he mentioned he would?
Peter Naglitsch is offline   Reply With Quote
Old 09-08-2009, 10:41 AM   #8
I've seen on all the wiring scheme that series wiring has to be made with the end of one coil into the start of the other one...
Old 09-08-2009, 01:19 PM   #9
Supporting Member
Quote:
Only if the coils are wound in the opposite direction.
Mike Sulzer is offline   Reply With Quote
Old 09-08-2009, 02:51 PM   #10
Pickup Maker
Not according to this:
Seymour Duncan Wiring Diagram
Notice the finish ends are connected to the finish ends of the coils for the series connection.
I had that same problem the first time I wired up a humbucker... 36 years ago. Just try swapping the wires and see what you get.
__________________
Old 09-08-2009, 11:36 PM   #11
Exactly! The friend who gave me the winder told me the same thing... and you're both right but my soldering iron was dead, I'll make a new connection tomorrow and will let you know
Old 09-12-2009, 11:02 AM   #12
Thanx guys! After speaking to a friend by the phone (he made pickups too) I realized I didn't swap the second bobin's wires color so I basically had to connect black with black to have series and humcancelling
Fixed this and the bass sounded extremely good... thank you!
Old 09-13-2009, 01:17 PM   #13
Hello
I made my first humbcker yesterday.
I wound the two coils in opposite directions, I used six 5 mm alnico magnets in each, one set north facing, one set south facing. I thought i had connected one end wire to the other coils start wire.
Results thin, weedy, no bass, out of phase and sounding like poo. (just what i wanted, not! ha!)
I swopped wires start to start and it resulted in a good strong signal.
Now i may have got it wrong with the wires as when i was ptting it together i snapped an other wire which i used 'fudged' to be a new end wire rather than trying to splice it back together.
Now i'm a bit lost, i have read the above a few times and please exuse me as i can be a bit slow at digesting things at times. (so i'm told!).
To make matters worse i took apart in the 'pursuit of knowledge' a cheap yamaha pickup, this had both END wires connected and both coils wound the same - clockwise.
1. Is the yamaha the 'right' way to do it, (ok, i know there is no right, just different).
2. If i did want to wire opposite directions, what do i connect the start of one to?
3. How do you (dear reader) do it? wind direction and connecting.
Thanks for any help, John
Bye the way very pleased with pickup, it sounds great, 12.5k plus i can switch it to single coil mode. Learned a lot from the forum, just foxed on the direction/connection business.
guitarsorguk is offline   Reply With Quote
Old 09-13-2009, 03:18 PM   #14
If you wind the coils in the same direction, connect the end of one coil to the end of the other (or start to start...). If you wind them in different direction you connect the end of one coil to the start of the other. That way the coils will be electrically out of phase. If you have two coils electrically out of phase and magnetically in phase the result will be as you first experience. The same thin happens if you have then electrically in phase and magnetically out of phase. The two coils need to be both magnetically and electrically out of phase. Kind of when minus 1 minus minus one makes minus two. The subject have been discussed a few time and there are better explanations if you do a search
Old 09-13-2009, 03:38 PM   #15
Pickup Maker
Quote:
Originally Posted by guitarsorguk View Post
Hello
I wound the two coils in opposite directions...
Most humbuckers are wound in the same direction. There's no real reason to wind in opposite directions, and it's more bother than it's worth IMO.
But do like Peter said. If you wind in opposite directions, wire the coils start to finish, or finish to start.
__________________
Old 09-13-2009, 03:52 PM   #16
Thank you david, i'm clear now.
Will create the next humbucker both the same direction. I have a couple of rewinds to do as well, just been waiting to get the right info before i make a start.
First Build, 5E3, strange problem, help please cfidave 5 E 3 37 12-22-2008 03:52 PM
Engl amp -strange problem! Valvehead Maintenance, Troubleshooting & Repair 6 12-15-2008 02:09 PM
strange champ problem sir 6v6 Maintenance, Troubleshooting & Repair 4 12-09-2008 08:33 AM
Strange pickup readings. Aka Nameless Pickup Makers 8 10-02-2007 02:10 AM
Strange Buzzing problem Gordon303 Maintenance, Troubleshooting & Repair 4 05-31-2007 01:41 AM
