Go Back   Music Electronics Forum > Amplification > Guitar Amps > Vintage Amps
Old 09-08-2009, 02:45 AM   #1
metallicafan's Avatar
Question gibson ga-45 maestro
i just found the schematic on this a few days ago so i'm hopefully going to get around to replacing the caps and resistors soon i was just wondering what i can do to tighten the bass response on it and possibly lower the treble just a little. it seems a little too bright to me and the tone pot just isn't getting it quite where i want it to be. also i was wondering if anyone has any advice on a new rectifier tube it has the 5y3 in it now and i know there a couple others that will swap without major modification but i can't seem to find too much about how the different rectifiers change the tone and feel of the amp. any help is appreciated and if you need any info on the amp to help me out just ask.
metallicafan is offline   Reply With Quote
Old 09-13-2009, 01:14 PM   #2
It's your amp but before I got to wondering about messing with its frequency response, I'd get the caps done including the cathode resistor bypass caps in the preamp, PI if present, and on the power tubes ... will make a substantial difference in the bass. Same with the 5Y3; you can put different 5Y3s in there and get subtle shifts in tone ... big shift if your old one is weak. Good luck with your amp. CJ
capnjuan is offline   Reply With Quote
Old 09-15-2009, 07:30 PM   #3
I agree with CJ's response - get it working as it was originally intended before modding it.
I will add that I serviced one of these a few months ago that benefited from two new coupling caps, the pair of .047uF caps that lead to the grids (pin 5) of the power tubes. A pretty easy repair that did not require removal of the circuit board. Since you mention replacing the caps, make sure you don't skip those two.
RWood
RWood is offline   Reply With Quote
Old 09-16-2009, 12:54 AM   #4
That's a rule in our shop - always fix it before you change it.
__________________
Old 09-16-2009, 01:03 AM   #5
RWood
thanks for pointing that out. i'm gonna do a full recap job and new tubes i just was wondering what i might wanna order with all that so once i get the recap job done if i still wanna change it i'll have it there already. would anyone recommend replacing the pots while i'm at it i need to replace the one for volume 1 but would changing the rest really change the tone any and also whats a good replacement/upgrade for the pots?
Tags
caps, gibson, maestro, rectifier
gibson GA-5T pontiacpete Vintage Amps 1 06-03-2009 02:47 AM
Gibson Maestro GA2-RVT(long) mbailey Vintage Amps 3 01-10-2009 05:41 PM
1961 Gibson Maestro M 216 RVT mark Vincent Flea Market 0 11-28-2008 05:26 PM
Maestro GA-1RT-1 Tremolo soontobe1968 Maintenance, Troubleshooting & Repair 4 12-11-2007 04:09 AM
Question on Gibson GA-16T and GA-18T amps slidincharlie (Carlo P) Vintage Amps 5 08-26-2006 04:27 AM
