Originally Posted by
peskywinnets
Having just tested my latest sustainer driver...alas, it looks like I'm going to have to go with even thicker wire (so much for my calculations! Actually, my driver does sustain, but I'd like a little more power in reservce on the top two thinnest stings). It's getting to the point now where, due to the thickness of wire needed & the lack of space if surface mounting, then I may be forced to go bobbinless...that prospect brought me back to your post David. I particularly curious about this bit...
Did you mean 'squirt the windings' on each successive coil winding 'layer' as the coil winds ...or just apply CA the final layer? If just the final layer, there must be a danger that the first few (&/or middle) copper wire layers will 'spring out' when removed from the faceplates?
But also, if you mean spray with CA while the coil is winding...then can the CA dry ok once covered with other windings (I'm no expert on CA, but doesn't it need air to 'set'). I'd have thought epoxy would be the thing to apply...but I'm all ears to the possiblity of winding a bobbinless coil in any way proposed!
