Who distributes them now? Pignose? DUnlop? SOmeone...
I just looked, it is Pignose. COntact them.
Mark, I don;t generally expect to need a schematic on these little things. All those basic practice amps are essentially the same. A TDA2030 or 2040 and one or maybe two op amps. You got signal on the output pins of the op amps or you don;t. The controls are all soldered in well or not, the controls are cracked across their wafers or not. The TDA is bad or not. The jack is screwed or broken, or the traces to it are torn.
LinkBack URL
About LinkBacks
