Go Back   Music Electronics Forum > Amplification > Guitar Amps > Build Your Amp > Tweed Builders
Old 09-10-2009, 02:52 AM   #1
Tweed Twin 5E8-A Finished Build
Here's a link to some photos of my finished build. It started as a Ted Weber kit and I added the following mods:
Vari-watt from Skipz-circuits
1K - 3 Watt screen resistors
1.5K - 1/2 watt grid stoppers on V1 and V2
Safety diodes (1N5408) on the rectifier
Single RCA 5U4GB rectifier
EH 12AY7 tubes in V1, V2, and V3
Shugaung 12AX7 in V4
RCA 7027A for the PA (biased at 45mA and 434 volts)
22 mfd/ 500 volt cap for first filter
Heyboer Multitap OT # 18343
Atlas Amps 5E8A Tweed Twin with Vari-watt - Album - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting
Diablo is offline   Reply With Quote
The Following User Says Thank You to Diablo For This Useful Post:
chuckb (01-11-2010)
Old 09-10-2009, 01:08 PM   #2
GR8 job!
layout is nice and neat.
how does is sound??
stingray_65 is offline   Reply With Quote
Old 09-10-2009, 07:47 PM   #3
Supporting Member
Very tidy - I'm keen to hear how the variwatt affects things (when you are ready)
__________________
Old 09-10-2009, 08:52 PM   #4
Thanks gentlemen. There were no problems with the build, and I didn't have to chase any strange hums or noises, so the ground scheme must be OK. I've never played or heard a 5E8A before this one, so it's kind of hard for me to give a critical comparison. I tried to find the 57 Tweed Twin RI at the local guitar center, but they don't have one in stock for me to play - but they'd be willing to order one for me..... It was funny, they'd never heard of a Tweed Twin before I mentioned it and told them it comes from the Fender Custom Shop.
Anyway, if I compare it to my 5F6A, the amp is more midrangey and at the same time very sensitive on the treble control. It also breaks up earlier with a more singing distortion. The Variwatt does work as described. I can adjust the plate voltage down from 434 volts to 12 volts, and the bias tracks along by itself. I can crank in huge overdrive when the VW plate voltage is reduced and sound like Led Zep, but I find the most use in it just reducing the plate voltage a little to get a little overdrive. The amp weighs 48.5 lbs on the bathroom scale, about 2 lbs lighter than the Bassman. I'm going to haul the amp over to a different music store to have some unbiased ears give me some feedback.
I still don't know how to upload or make videos, so I can't let you hear it. Maybe some day.....
Old 09-13-2009, 06:49 PM   #5
Well I thought I was finished, but decided to do a little tweaking. I added a 150K resistor across the treble pot connected to the ground switch, so I can change the voicing of the amp - scooped midrange. Goes from Tweed Twin to a not quite blackface.
Duncan Tone Stack Calculator
Old 09-14-2009, 12:34 PM   #6
Supporting Member
... yes I too find that the tweaking usually goes on for some months after the build is 'finished' ...
__________________
Old 12-14-2009, 09:35 PM   #7
Another tweak. I changed the power scaling from only the power tubes to the whole amp. This reduces the overall gain available, but there's still plenty for me. And it just sounds better.
Old 12-17-2009, 03:10 AM   #8
And yet another tweak. Swapped in a pair of EL34s in place of the 7027A tubes. The amp now has less of a Fender flavor. According to the local music store owner, he thinks it sounds like a Hiwatt. The EL34s add some bass and midrange punch and change the tone of the overdrive.
Old 12-29-2009, 01:39 PM   #9
Good looking build!
Big Mike is offline   Reply With Quote
Old 12-29-2009, 09:47 PM   #10
Thanks all for the kind comments.
Tweed Twin 5E8-A Grid Resistors? Diablo Tweed Builders 3 09-05-2009 09:04 PM
5E8-A Tweed Twin Output Transformer Diablo Tweed Builders 3 08-22-2009 08:23 PM
5E8-A tweed twin. Volume cuts out at 8 corduroyew Debugging Your Build 2 10-29-2008 05:43 AM
5E8 twin step by step guide? nate_hiltz Tweed Builders 3 07-26-2008 11:20 PM
Just finished my first build milocj 5 E 3 8 02-27-2008 05:03 PM
