Go Back   Music Electronics Forum > Amplification > Guitar Amps > Mods & Tweeks
Old 09-12-2009, 03:01 PM   #1
V32 -reducing brightness on clean channel?
Ive modded my V32 with good results aimed mostly at the dirty channel. The clean channel is too bright for my tastes with humbuckers even. Looking at the schematic Im wondering if clipping(or making it switchable) the C52 will tame the brightness. TIA-Bob
http://www.schematicheaven.com/newam...2_palomino.pdf
__________________
"Reality is an illusion albeit a very persistant one " Albert Einstein
rockon1 is offline   Reply With Quote
Old 09-12-2009, 04:51 PM   #2
Yes, C52 is a "brite cap" and reducing the value would tame the highs, especially at low settings of the volume control. Also, C37 is a mild "treble peaking" circuit. It allows some of the highs to bypass that 2.2M resistor. It may help to remove this, but first try some lower values (or switch out, like you said) C52.
reverendbk is offline   Reply With Quote
Old 09-13-2009, 02:43 PM   #3
Thanks! It helps a good bit taking the C52 out of the circuit. I made it switchable but had some intermitant trouble with noise. I temporarily shielded the wired and that helped. I guess I need some two wire shieled cable to use the switch. Bob
__________________
Old 09-14-2009, 08:37 PM   #4
Glad it helped the brightness issue. Not to assume, but make sure the brite switch is dressed properly. I know my own tendency used to be to sort of cram it in there; i wasn't careful because it's such a simple mod. Sometimes part of the switch would touch ground (usually via the back of the pot) and cause trouble. Also, I'm not 100% on this, but the 2.2M resistor would be in series with the volume pot w/o that cap, which may cause a hum. Again not sure about that one, maybe a more experienced member can comment on that...
Old 09-14-2009, 10:16 PM   #5
Quote:
No hum but unshielded I seemned to get an "osillation"? which went away went I wrapped both wires in tin foil and shrink wrap with a third wire coming from inside the shrink wrap to ground. Im going to have to redo it with the proper shielded wire! Bob
__________________
Reducing gain in dirty channel rockon1 Mods & Tweeks 8 09-12-2009 04:31 PM
TSL Clean Channel Buzz PaoloJM Maintenance, Troubleshooting & Repair 6 09-09-2009 11:49 AM
Fender Twin Amp - Gain channel sucks, clean channel has limited Bass TerryCline Maintenance, Troubleshooting & Repair 5 07-16-2009 06:45 PM
Increase clean channel headroom? GlideOn1 Mods & Tweeks 10 08-21-2008 01:54 PM
Clean Channel Tone Stack chunkitup Mods & Tweeks 2 05-21-2007 04:34 PM
