| | #1 |
| Junior Member Join Date: Jan 2009 Location: California
| Help w Volcano hot EL34 on Music Man 210HD 130
Hi, I could use some help/advice here. I'm working on an old Music Man amp for a good friend. This one has had a frustrating issue for years of working fine for about 30 minutes or so then a hum comes out of the speakers and one of the 4 EL34 (6CA7) is fire-red hot. The original tube I pulled out has deformed glass. After inspection - nothing found - I changed the electrolytic caps, re-tubed and biased; hoping that there was a bad tube causing the problem. No dice, 30 minutes of playing on this very good sounding amp and here we go again. Once it cooled down it was ok again. I'll remove the chassis again and measure what I can statically but I'm scratching my head. I am wondering if it's an output transformer heating up, or even the power supply. Although it appears to be related to the one tube next to the OT. Has anyone come across anything like this? Advice on how to proceed? I have some pics posted in this album: Music Man 210-HD pictures by ElBrewski - Photobucket Here is the schematic http://www.music-man.com/techinfo/ol...&_2275-130.pdf |
| | #2 |
How did you bias it? These are class B amps and supposed to be biased to almost zero mA at idle. If it's always the same socket where the tube glows, maybe a bad or dirty contact. HTH Albert |
| | #3 |
| Member Join Date: Aug 2009 Location: Seattle, Washington
Am I reading this right? It looks like the signal drives cathode sinks (Q1, Q2). If one of those is failing, you would probably have a runaway condition...
| | #4 |
| Supporting Member Join Date: May 2006 Location: Glasgow, Scotland
Yep, but that would affect two tubes, since each transistor drives two. If it was one of those trannies, I'd expect it to fail catastrophically and make both tubes glow bright red, or even blow a fuse. I suggest checking R55, R57, R60, and R62 for bad solder joints or loose connections, also check the resistance of them is correct, as well as cleaning and retensioning the power tube sockets. These amps are a bit feisty with their 700 volt B+, be careful in there!
__________________ "Ohhhh miracle bulb shines feebly" |
| | #5 |
Whether or not it's the same tube socket each time could be significant, with 700 Volts on the plates I wouldn't be too surprised if (when retubing) you found another one that just couldn't handle it.
| | #6 | ||
| Quote:
yep - the idea of 725v in the area sure keeps my attention. Quote:
Music Man Amps Discussion Forum: Setting Bias on Music Man Amps | ||
| | #7 | |
| Quote:
Maybe try biasing a little colder and watch what happens. Of course check all the resistors, contacts and solder joints first, like Steve said. Cheers, Albert | |
| | #8 |
Oh, if it has a 12AX7 PI, then check the usual stuff: leaky coupling capacitors, bias feed resistors that have gone open, etc. as well as those four stopper resistors. You posted the schematic for the later one with the transistor drive to the cathodes. Something of an outside shot, though, since again a leaky coupling cap or bad bias feed resistor should make two tubes go "volcano", not just one.
| | #9 |
| Member Join Date: Jun 2009 Location: Germany
Leaky caps would kill at least two tubes but the "problem" was seen only on one socket so I would focus on this one, maybe it has a bad socket contact or a open/bad stopper resistor. Evaluate them carefully, sometimes they do crack and still measure right when cold but open up when getting warm. When replacing the tubes get tough ones which can handle the voltages seen in these amps. BTW: How did EL34 get into this amp? Originally this version was shipped with either 6L6 or 6CA7 tubes...
__________________ I can fix everything, where is the duct tape? Last edited by bluesfreak; 09-14-2009 at 02:14 PM. |
| | #10 | ||
| Quote:
It's possible that the other tube in the pair is getting hot as well, but it definitely was not as hot visually - I shut it off very quickly when it happened. So I'll check for issues suggested here that can affect one or both. The replacement tubes I bought are Electro-Harmonix 6CA7EH, I was under the impression that EL34 and 6CA7 are essentially the same, based on the description: "A direct replacement, with military reliability, for any EL34." : Electro-Harmonix 6CA7 EH Hopefully these are tough enough. Quote:
Thanks for all the advice, I'm going in... | ||
| | #11 |
EH specs the 6CA7 for max. 800V in Class B so be careful. Ensure that the Grid Stoppers are 1k or 1.5k at least. I still suspect one of these failing causing the tube to go nuts...
__________________ I can fix everything, where is the duct tape? |
| | #12 |
It is dissipation, hence current, that will kill the tube, not the voltage.
| | #13 |
I imagine that beyond a certain B+, the tube may not be as stable or reliable... Amp designers seem to have been exceeding Vmax ratings for decades, but I have always thought they were stated by the tube manufacturer for a reason.
| | #14 |
They ARE stated for reasons. It is just that when you run the tube way over, it is till how much current flowing through it that will ultimatey burn it up... or not. At 700-800v on the plate, each milliamp increase in current is also 3/4 of a watt. When RCA says X voltage is the design max, they are telling you, the designer, that they will consider your design proper adn expect long reliable life from their tubes if you stay within them. Mom and Dad did not want to replace the 6BQ5s in their table radio twice a year, but we in guitar amp land consider that normal. When they tell you 300v on a plate, that doesn;t mean 301 will arc the tube. It means that when Leo Fender gets away with running 6V6s 100v over the book, he can;t go crying to RCA that their tubes don;t hold up. Not that his amps were tube eaters.
| | #15 |
Well said. I appreciate your clarity. And the image of Leo Fender crying to RCA is especially nice... I suppose I am always particularly concerned about reliability. I want to keep the chances of an amp going down at a gig low, and I want to know what to expect when pushing the limits. I'd rather the tubes just wear out tone-wise every 6 months, than sound great until catastrophic failure at 12. I was under the impression that higher dissipation corresponded more so with the former, but Vmax always had the portent of the latter...now that I think about it, I'm unsure. By the way, in your experience, how high of a voltage can 6V6's reliably tolerate in guitar amps?
| | #16 |
normally 400Va is the max for a 6V6 but JJ 6V6 are more robust and can handle up to 480V
| | #17 |
After further (static) inspecting and measuring resistors and whatever else in the areas of concern, it all looks ok - which I more or less expected given that it works fine until it heats up. So I put together a Mouser order for resistors and signal caps to replace those that are the most likely suspects, based on the advice given. When those come in my plan is to replace parts, re-tension the socket contacts and then power up and adjust the bias setting cooler. Have I missed anything? |
| | #18 |
Sounds like a plan Don't forget to resolder the tube socket connections and make sure none of the contacts are broken inside the socket. |
| | #19 |
Update: After replacing grid resistors on sockets & coupling caps on the driver board, re-tensioning socket pins and reducing bias from .5v to .32v... I played it for almost 2 hrs with no problems, the tubes had a perfect glow and the thing sounds great. Although I need more time to be certain, for now I am calling this amp repaired! I'm not sure what exactly fixed it, I'm leaning toward the cooler bias. Thanks to everyone's advice here, this is a great forum. I added some pics of the parts replacement, before and after. Note that the coupling caps leading to the output tubes had been previously replaced with a large disc type that I'm not familiar with. Music Man 210-HD pictures by ElBrewski - Photobucket |
| | #20 |
Congrats! PS: Those .1/1kV disc caps were probably ok, but ODs sure are a better choice. |
| | #21 |
So after a few playing sessions over the past week+ the amp still runs fine but this animal has a dual power switch labeled Hi, off and Lo. I've been testing in the Hi (130W) mode so that it runs as hot as it can. But I thought I better try the Lo (65W) mode as well and it turns out it has a moderately distorted sound - almost like a low quality overdrive pedal. I don't know for sure if this mode had a problem before I started working on the amp, but I really don't believe so. I am guessing that I have brought the bias down too low for the low power mode to run properly - I had moved it from .5V to .32V - and what I'm hearing could be cross-over distortion. Does this sound likely? I have no experience with hearing what that would sound like. I am tempted to plug in my (recently acquired) sine wave generator and looking across the speaker contacts with my o'scope for a look see. From the schema it appears that the Hi/Lo switch uses more primary windings on the PST when in the Lo mode, thereby lowering the secondary voltages. ![]() I was thinking that raising the bias up by some amount and trying it, maybe up to .38V, then higher; but I don't want run this thing too hot or I could be back to square one. Any thoughts? |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| music man circuit breaker | merckx5312 | Maintenance, Troubleshooting & Repair | 1 | 01-19-2009 06:13 PM |
| Music Man RD110-30 | lowell | Maintenance, Troubleshooting & Repair | 0 | 12-09-2008 11:33 PM |
| Music Man RD 110 | lowell | Schematic Requests | 1 | 10-29-2008 04:17 AM |
| Music Man Capacitors | WholeToneMusic | Maintenance, Troubleshooting & Repair | 13 | 09-16-2008 07:22 PM |
| Music Man 410 HD 130 | ORocket | Vintage Amps | 1 | 04-17-2007 11:41 PM |
