Go Back   Music Electronics Forum > Instrumentation > Guitar Tech
Old 09-14-2009, 02:12 AM   #1
Between F-spacing and Gibson spacing
Hello everyone,
I recently purchased a Jim Root Tele. This is my first tele and I have been playing on a gibson explorer with a kahler for the past 7 years. Needless to say I'm used to a very thin neck and since the kahler has adjustable saddles, very small string spacing (close or smaller than gibson spacing).
I'm curious if theres any way to decrease the string spacing on a tele. Whether using different saddles or a whole new bridge. I feel like I could only make a small change, since the string holes are routed into the guitar. I've been searching and haven't found anything, nor do I know if my saddles are 2 3/32 or 2 1/32 spacing, I would have to guess the latter. The spacing is fine at the nut, but it just fans out and makes playing anywhere past the 7th fret difficult.
shef86 is offline   Reply With Quote
Old 09-14-2009, 08:16 AM   #2
There's no good news for you. The only bridge I can think of that will adjust to the spacing you'd like is this:
Chrome Non-Tremolo Bridge | Allparts.com
You could try notching your tele saddles to a narrower spacing, or going with the "threaded" type barrels, but That may cause tuning problems. Ultimately, if you're used to narrower than old Gibson spacing, you're going to have to switch or fight. You may have just found out the hard way that you're just not a Fender guy. You could have a Tele custom made with a narrow neck/string spacing.
Sweetfinger is offline   Reply With Quote
Old 09-16-2009, 06:34 PM   #3
Don't be such a pussy and just man up and play it. You'll adapt and it will cost you nothing. And you will have expanded your musical horizons. Now won't that make you a better person too?
Happy to Help
Charlie
TheElectricMoron is offline   Reply With Quote
Old 09-16-2009, 09:42 PM   #4
Pickup Maker
David Schwab's Avatar
I have to say, I have several guitars with the spacing slightly different, and I don't notice it at all. You'll get used to it.
__________________
Those who create are rare; those who cannot are numerous. Therefore, the latter are stronger. - Coco Chanel
www.sgd-lutherie.com
www.myspace.com/sgdlutherie
www.myspace.com/davidschwab
David Schwab is offline   Reply With Quote
Pole spacing for these two Gibson HB's RedHouse Pickup Makers 8 08-29-2008 12:15 AM
J an P Bass spacing mick Pickup Makers 15 04-13-2008 11:00 PM
stewmac bobbins and gibson spacing? Possum Pickup Makers 38 08-29-2007 12:16 AM
Componenet Spacing zorro Theory & Design 6 04-11-2007 02:09 PM
Tagboard spacing jaydawg 5 E 3 4 06-12-2006 02:00 PM
