| | #1 |
| Junior Member Join Date: Sep 2009
| Buckethead Kill Switch
I would like to install in my selector spot on a LP copy. What is the exact type of switch I need. I tried a crap one from radio shack and it was garbage and didnt work right. And also where to wire it in at. Thanks |
| | #2 |
| Senior Member Join Date: Apr 2008 Location: PDX
the buck uses a small push button switch of unknown type, typically you want a small "normally open" single pole momentary pushbutton with a threaded bushing that's long enough to go through the guitar top. Measure the thickness with a tone or vol. pot out. Mouser would have many types, this one might work MB2011SS1W01-RO NKK Switch Pushbutton Switches the trick (I got wrong initially) is to us a "normally open" (NO) switch which takes the signal from the pickups (before the jack naturally) and puts it to ground when pushed. A normally closed on the signal which just cuts it off is noisy as all hell. Other just set the neck PU to zero and use the pickup selector switch, but this is crude. You want a dynamic kill switch, while playing, right? It sure makes those speakers jump! |
| | #3 |
| Member Join Date: Oct 2009 Location: SF Bay Area
Just thoughts jumbling in my head: Have you looked into an ignition push start button for a car? I'd look for a low amp one designed for a relay, not a high amp one. I bet those would be made to 1000x higher standards than radioshack junk.
| | #4 |
| Pickup Maker Join Date: May 2006 Location: Montclair, NJ
Radio Shack parts are not really junk. I've had many of their switches and pots in guitars that have been working fine for the past 30 years. You can pretty much buy the same parts from Mouser, or one of the other electronic part catalogs. |
| | #5 | |
| Quote:
Radioshack brand actually used to be very competitive and good, but all their new stuff is just rebadged from another brand, so there's no guarantee it'll be ANY good, or the same from year to year since it's all based on lowest bidder mentality. | |
| | #6 | |
| Quote:
They simply stock parts from other manufacturers. Even their speakers were made by companies like Electro Voice... Except for Tandy wire and computers, Radio Shack never manufactured anything at all. Everything was out sourced. The point is that Radio Shack carries Alpha pots... Stew Mac carried Alpha pots.. other places carry Alpha pots... the only difference is in the shafts. Stew Mac sells pots with split-knurled shafts, while RS carries pots with solid long shafts you have to cut to length. You can get better quality Alpha pots from places like Mouser, but they aren't junk parts. Even the switches and stuff RS carries are lower end versions by regular manufacturers. Yes there are better quality parts out there, but these aren't bad in a pinch. The unfortunate part is since RS is de-emphasizing electronic parts over consumer electronics, the quality of some stuff like mini toggle switches isn't as good as they used to be. The switches work fine, but feel stiff. So if you choose wisely, there's shouldn't be a problem. I'd stick a radio Shack push button in a guitar as a kill switch, and if I wanted something better, get a switch from a real electronic parts source. Radio Shack Catalog Archive from 1939 | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Will my killswitch kill my pre-amp? | varietyshowjoe | Guitar Tech | 4 | 04-29-2009 06:57 AM |
| Can too much B+ filtering kill a rectifier? | zhyla | Debugging Your Build | 2 | 03-21-2009 11:46 PM |
| Time to kill amplog? | Mark Lavelle | Lobby | 0 | 12-19-2006 05:13 AM |
| help me kill my synth | angelo | Guitar Effects | 11 | 11-25-2006 08:43 PM |
| will this kill my power amp/OT? | nicodemus | Mods & Tweeks | 11 | 08-19-2006 11:32 AM |
