| Music Electronics General discussion about music electronics |
| | #1 |
| Senior Member Join Date: Jul 2007 Location: Indianapolis
| Teeth-sucking squeal
Guys, what sort of symptom is a squeal that sounds about like sucking air through your teeth (a little lower-pitched than that, but a similar sound). This Hammond M-101 has a squeal like that in the reverb amp (NOT in the speaker, but in the amp). It goes away if I wiggle the 12AX7 or 6C-something in its socket. Is that a croaking filter cap or an actively frying transformer? Thanks! |
| | #2 |
| Junior Member Join Date: Sep 2009 Location: uruapan michoacan mexico
maybe what you think, but also sounds like arcing on the pins of the tubes you're moving, i would check (without power and caps discharged) the sockets for visible signals like blackening or something, maybe they're just lose or need to replace, also look for any sign on electrolitycs leaking, they make those noises too!! good luck !! and dont let it grow worse!! martinnez |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| fx loop sucking tone | cris9288 | Maintenance, Troubleshooting & Repair | 4 | 06-24-2009 03:17 AM |
| champ clone squeal | tubby | Debugging Your Build | 7 | 01-11-2009 01:00 AM |
| Marshall jcm900 squeal at power off | hollisdevillo | Maintenance, Troubleshooting & Repair | 1 | 11-02-2008 10:32 PM |
| Crybaby + SD-1 = squeal | ronh | Guitar Effects | 2 | 11-01-2008 03:02 AM |
| Getting my wisdom teeth out! :/ | Steve Conner | Lobby | 4 | 04-06-2008 04:19 AM |
