Go Back   Music Electronics Forum > Amplification > Guitar Amps > Build Your Amp > Conversions
Old 09-22-2009, 10:25 PM   #1
Exclamation El34 to 6V6 conversion
HI ALL!
I have a JCM900. i would like to convert the stock EL34's to 6V6's
I wanna do this in order to bring down the power output a bit. I suppose i would have to set the impedance selector switch one down? ANYWAY, Does anyone have a procedure do this? Any help will be much appreciated!!
didi is offline   Reply With Quote
Old 09-22-2009, 10:31 PM   #2
olddawg's Avatar
Quote:
Originally Posted by didi View Post
HI ALL!
Yellow Jacket adapters?
olddawg is offline   Reply With Quote
Old 09-23-2009, 02:08 AM   #3
I've done a similar conversion with my Hiwatt, and it was as simple as re-biasing. I set them up for about 10w. Very pleased with the results, and it might work with your Marshall, but I'm not so sure. Some important caveats:
Use JJ 6V6's - they can withstand the abuse.
Your plate voltage needs to be within the range a 6V6 will take. (The Hiwatt was 470 - I guess the marshall is much higher)
Expect lower tube life expectancy.
When I was told aout this conversion, I was told If using an 8 ohm speaker load, set the output impedance for 4 ohm.
porge is offline   Reply With Quote
EL34/EL84 versus 6V6/6L6 PRNDL Theory & Design 7 05-29-2009 09:43 PM
EL34 to 6V6 impedance question. rockon1 Mods & Tweeks 2 12-28-2008 12:22 AM
EL34 vs 6V6 daz Theory & Design 8 06-25-2008 07:58 AM
Converting EL34 to 6L6/6V6 EETStudent Maintenance, Troubleshooting & Repair 2 01-10-2008 12:39 AM
El34, 6l6, 6v6 russ_guitarboy Tubes (Valves) 6 05-23-2007 08:12 PM
