| | #1 |
| Junior Member Join Date: May 2009
| AMPEG SVT 3 Pro
Amp keeps blowing V3, I have replaced it twice with a EH12ax7, need help, please |
| | #2 |
| Senior Member Join Date: Jul 2006
You could have just been unlucky.. all I can suggest is check the voltages as per the attached schematic and make sure the 120v is not getting through a leaky C19. Dangerous voltages inside so be careful let someone know what you are doing . Does it sound ok when its going ? |
| The Following User Says Thank You to oc disorder For This Useful Post: | cgates56 (09-23-2009) |
| | #3 |
What do you mean by "blowing?" V3 is just a preamp tube, not under any stress. Shouldn't be much the circuit could do to it. But it is a cathode follower, and in this circuit it has about 120v on the cathode. SO some brands of 12AX7 object to high cathode voltage. Try a different brand.
| | #4 |
Looks like the tube is shorting, the filaments do not light on my tube tester , where a known good one does, I replaced V3 again with a NOS 12AX7 and the amp is up and running again I will just have to run it a few days and see, I have also order a set of JJ's that were in the unit from the factory and will install these, they should be in in a few days.
| | #5 |
| Fixed
I replaced all the tubes with JJ's and solved the problem, thanks for all the help. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Ampeg SVT-5 Pro distortion | bnwitt | Maintenance, Troubleshooting & Repair | 32 | 02-27-2010 12:35 AM |
| Help, Need a schematic for an AMPEG SVT 3 Pro | cgates56 | Schematic Requests | 2 | 09-23-2009 01:33 PM |
| AMPEG SVT lll PRO | keysnleslie | Other Amps | 12 | 05-01-2009 11:18 PM |
| Ampeg SVT-4 Pro | LocoBassPlayer | Other Amps | 8 | 01-22-2009 12:49 AM |
| Ampeg Svt 4 Pro | PrimoCapone | Music Electronics | 1 | 07-17-2008 07:39 PM |
