Old 09-24-2009, 06:22 PM   #1
Dual Showman low freq oscillation
Hi,
I received just some hours ago a Dual Showman I bought off ebay. The amp was sold as recently refurbished by TAD, which probabily is: Sprague caps and TAD brand inside, new power tubes etc.
I took it off the box, connected it, and "vibrato" channel worked ok, while the "normal" made no sound. I tried to lightly poke the preamp tubes, and they seemed to be quite loose in the socket. I tried to push them in firmly, played some more notes and one of them must have moved because a loud rumbling noise was produced.
So I took the head out of the cab, checked if the wires attached to the sockets were ok - and they were - the tightened the sockets' pin holders a bit with a tiny screwdriver. Put the amp back in, plugged the tubes in the sockets, and now as soon as I release the standby switch, a loud WOOOOO noise comes out of the amp. Poking the tubes changes nothing. The power tubes light up normally, and I swapped all preamp tubes with no extent.
any suggestion?
regards,
Maurizio
capomonster is offline   Reply With Quote
Old 09-24-2009, 07:10 PM   #2
-edit-
I tried to switch the amp on with no v1 nor v2 in. something happened first, then I put v2 back in, the noise came again. but, i was not so quick to switch it off, so the noise slowly increased the disappeared. amp off, then on, no noise. both valves back in, no noise. strummed a bit... the noise seems to be gone!
can I trust the amp now? maybe it was some cap that needed recharging?
(sorry for the bad tech language)
regards,
Maurizio
Fender Dual Showman bias/balancing ian1739 Maintenance, Troubleshooting & Repair 10 02-17-2009 09:30 PM
Dual Showman Chassis mitchb_199 Build Your Amp 1 10-05-2008 06:58 PM
Black face Dual Showman ??s THX1136 Maintenance, Troubleshooting & Repair 8 09-27-2008 12:57 AM
Low pass cut-off freq studioit Theory & Design 4 08-19-2008 10:12 AM
5e3 low freq. hum tubelovin Debugging Your Build 1 06-30-2006 02:04 PM
