Go Back   Music Electronics Forum > Amplification > Guitar Amps > Build Your Amp
Old 09-25-2009, 07:56 PM   #1
6g2 Brown Princeton, PT?
Anyone know what Power Trans to use for a Brown Princeton 6G2 Clone? The schematic shows a 125P1A, but I cannot find anything on this. Any help is appreciated. Thanks!
gtrrich is offline   Reply With Quote
Old 09-25-2009, 09:33 PM   #2
Supporting Member
loudthud's Avatar
I'm finding equavalents of the 125P1B at Antique Electronic Supply and the specs look adequate.
__________________
WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personel.
loudthud is online now   Reply With Quote
Old 09-25-2009, 10:37 PM   #3
Supporting Member
I can't see it at AES, but with those low voltages I'm guessing the HT is around 290-0-290 (or 300-0-300 for slightly more headroom) @70mA (which I'd spec at 100mA for a bit less sag). 2CW
__________________
Old 10-13-2009, 02:11 AM   #4
Quote:
Hammond 290AX.
Hammond Mfg. - REPLACEMENT & UPGRADES - Tube Guitar Amplifier - Power Transformers
RichardBM is offline   Reply With Quote
Old 10-17-2009, 09:05 PM   #5
Thanks everyone for your input. I've been doing some more checking on this, and I found that Mercury Magnetics has both PT and OT for this amp. No specs on their site though. I would like to make it versatile by being able to use 6L6s as well as 6V6s. I'm considering:
for Power Trans:
Hammond 272DX 300-0-300 144mA
6.3 @4A
5.0 @ 3A
I might have to knock down the B+ with zeners as I have seen others do in other posts.
Output Trans:
Hammond 125E
15W (not sure if thats enough with 6L6s)
selectable output imp.
I'm starting to think it would be easier to stick to the schematic and not try the tube swapping thing. Any thoughts appreciated!
Old 10-17-2009, 09:28 PM   #6
Supporting Member
Allen Amps has some good Heyboer transformers that would work well in this. Probably a lot cheaper than MM too.
Allen Amplification - Parts Order Page
JoeM is offline   Reply With Quote
Old 10-19-2009, 07:30 AM   #7
Senior Hollow State Tech
Bruce / Mission Amps's Avatar
Unless Dave specifically says the transformers are Heyboer then I would not publish or suppose they are Heyboer.
Yes, they are superior/excellent quality transformers and very well priced... etc.
When upgrading some amps to heavy duty use, (like a Princeton Reverb or Deluxe Reverb) I always call on Dave and have him send one of his HD PTs rather then reinvent the wheel.
Depending on the rectifier chosen and what you want to bias the power tubes at, anything around 300vac to 320vac@ 90ma-120ma will work fine for a Brown Princeton clone.
__________________
Bruce
Mission Amps
Denver, CO. 80022
www.missionamps.com
303-955-2412
Bruce / Mission Amps is offline   Reply With Quote
Old 10-19-2009, 07:56 AM   #8
I used the MercMag. BFPR PT and the Triode Electronics Deluxe OT (6.6k, paper bobbin) in my 6G2 clone. Sounds good to me, and to everyone who's played it.
andrew_k is offline   Reply With Quote
Old 10-19-2009, 04:54 PM   #9
Supporting Member
Quote:
Quite true, some he refers to as "Allen/Heyboer" others as Hammond. Others are not stated.
Old 11-07-2009, 01:48 AM   #10
Howlin' Mad Mac's Avatar
6G2 Transformers
Please tell me if I'm incorrect but I was imformed that most Champ, Princeton (non-reverb) & Bronco models used the same PT. I believe the 6G2 uses 2-7025/12AX7's, 2-6V6's & a GY3 rectifier so should supply enough current. I only ask cause I've ordered up parts as I've been wanting to build one myself.
__________________
Hey you... Yeah you kid... Ya wanna buy some "Magic Beans"?
Howlin' Mad Mac is offline   Reply With Quote
Old 11-07-2009, 04:18 AM   #11
From what I have seen, the single ended amps (champs, bronco, some princetons) use the 125P1B. There are plenty of PTs out there to replace it. However, the Princeton 6G2 circuit uses the 125P1A. I could not find specs on this one. I ended up using the Hammond 272DX power trans, and the OT20PP output trans (from musicalpowersupplies.com) for the output trans. If you're building a 6G2, I'd be curious to know what your using.
Old 11-07-2009, 07:41 PM   #12
Yes the A was replaced by the B or at least that is my understanding however the differences are considered so minor as to not make any kind of sonic difference or at least enough of one to worry about it. Use the B & it'll sound fine... that's what everyone else does.
__________________
Old 11-09-2009, 10:42 AM   #13
RichardM's Avatar
Location: Ocean View, 59Km North of Brisbane, Australia
Mercury Magnetics Princeton:-
"FBPP Early '60s Brown -- #125P1A"
or
"FBFPP Blackface -- #125P1B "
__________________
Richard _/_/_/_/_/_/_/_/_/_/_/_/_/_/_/
"Sorry for the Inconvenience."
RichardM is offline   Reply With Quote
Old 11-11-2009, 06:53 PM   #14
Yeah for my build I ordered my transformer from Antique Electronics Supply. I forget what brand it is although I know it's not a Hammond as it was made in Chicago, not Canada & it's the one with a "B" in the part no. As for the Mercury Magnetics trannies I'm sure they're quite good & all but they're still just laminated iron & magnet wire & I'm just not willing to pay big $$$ for some orange paint & a slick advertisement... I believe in buying quality American (or Canadian) made parts whenever possible & paying more for them. Over-paying is a different story, I'm too frugal for that.
__________________
MM Princeton Reverb OT & PT FFM Mods & Tweeks 0 03-12-2009 11:14 AM
Isn't the Princeton Reverb PT undersized? Victor Denance Vintage Amps 9 03-06-2009 05:18 PM
Confused about OT selection for PP 6V6 (6G2) andrew_k Build Your Amp 2 09-25-2008 05:01 AM
5y3 GT in 6G2 Princeton distorto Maintenance, Troubleshooting & Repair 9 08-19-2008 06:16 PM
PT current rating for 6L6 in Brown Princeton pete_b Tweed Builders 2 06-13-2006 10:31 PM
