| | #1 |
| Junior Member Join Date: Jul 2009
| Dual Output
So I've been thinking lately about some really interesting wirings for and old SX bass I've got lying around. I've got a concept I'm really excited about but I'm not sure how to apply it. I was wondering if anyone could give me clues as to how to wire it up so that multiple pickups can go to mulitple outputs. In other words, three pups that can be switched on or off on two different outputs. I can't think of a way to allow the same pickup to go to two outputs without combing the two into one circuit and making the outputs identical, which is exactly what I do NOT want - identical outputs. |
| | #2 |
| Pickup Maker Join Date: May 2006 Location: Montclair, NJ
I had a stereo Vox Phantom 12-string once, and it had three pickups with each half (under 3 pairs of strings) which could go to the left or right output. It had 3 way switches for each pickup which was off in the center, and then on left or on right. It used Strat type lever switches, but you can do it with mini toggle switches. So get a SPDT (or DPDT if they are easier to find) center off toggle switch for each pickup. You wire the pickup to the center lug, and each output to the other two. |
| | #3 | ||
| Member Join Date: Sep 2009
I toyed with a similar idea for my old Performer P/J bass that I wished to convert to an M1/P/J (M1 being the DiMarzio Model one or something akin to that) with stereo outputs. Quote:
Quote:
| | #4 | ||
Later on, while considering the many possible wirings I've read about, I recalled an old discussion going about Rickenbacker replacement pickups. Of all the manufacturers who made those (and there aren't many), Bartolini had a little extra - a micro-pickup that fit inside the muting foam compartment inside the bridge, and it was commonly wired in parallel with the neck pickup. So, following that little idea, I once again deferred to tubby.twins for extra ideas: Quote:
Quote:
| | #5 |
Originally those Bart Hi-A mute pickups worked like a regular pickup. Then they made them so they just added to the neck pickup. I borrowed that idea and put a single coil pickup in the mute compartment, and had it wired like a regular pickup. It was some bobbin from an old Teisco or something. Then I added a Dimarzio Model P between the neck and bridge pickups. I also changed the toaster for an old Carvin humbucker. I had a lot of switches on that bass! I had a Hi-A pickup in my '74 Rick at the bridge. I got that back in 1977. It was one of the first humbuckers he made. The older models had one coil per string. |
| | #6 |
David - that's pickup's grand-son (the Bart 6JH) is what originally set me off thinking the fourth position (the MM||J -> 1, P -> 2) would be worth the experiment. The exact thing you describe (the Hi-A mute compartment pick-up being complimentary to the neck 6RT) is what drove me to look for the final solution. I seem to recall you yourself posting in the exact original thread, asking why I wouldn't include all the pickups in the setup. Considering the original idea (that it'd be a stereo output system) - I hope this answers that question asked long ago. Of course - at this point I'm just talking out of my hindquarters, as I haven't verified the wiring myself - but I figure it might work by some odd sense. |
| | #7 |
I remember thinking the Rick's stereo outputs would be cool, and at one point ran each pickup to a 10 band EQ. But eventually I wired the bass up as mono, mostly because I added two more pickups and things like varitones. It was far more useful to have all the pickups feed into a single preamp. But it was cool to stick the Brassmaster on the bridge pickup and an EH Mole on the neck. Lately I'm thinking I'd like to have active tone controls for each pickup before I blend them together. Currently all my working basses are passive while I do some restoration on my main bass, and as I'm building my prototypes for a preamp. I haven't played a passive bass in years, but it's not that bad. Tubby's wiring ideas are pretty interesting. On his latest bass, I expected the "virtual" positions between pickups to be a little more distinct, but I also told him I though mixing two pickups together has some cool tones, which is the way he's doing it now. It looked very cool seeing three of my pickups on his bass. |
| | #8 | |
| Junior Member Join Date: Sep 2009
| Quote:
And yes, the new switching scheme is proving to be very nice. I'm really enjoying the new blended tones. | |
| | #9 | |
| Quote:
I'm working on that new/old bridge pickup... I'm going to try some new ideas. | |
| | #10 |
Hey, tubby.twins, glad to see you here as well. As I said, the three-pickup idea is on ice for the time being - however, the quad-coil-MM switching schematic you provided me with might soon come to fruition, as the warranty on my six-string with the humbucker just expired two days ago. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Dual Rectifier Tubes | Fletcher Munson | Theory & Design | 5 | 11-02-2008 01:18 AM |
| Dual Showman Chassis | mitchb_199 | Build Your Amp | 1 | 10-05-2008 07:58 PM |
| Filmosound dual pot | atmars | Conversions | 16 | 07-02-2008 02:41 AM |
| Mesa Dual Recto 3 channel schematics+Dual recto problem | kusan | Guitar Amps | 0 | 06-26-2007 12:19 AM |
| Optocouplers/ dual opamp Q | The Captain | Guitar Effects | 16 | 04-16-2007 07:54 PM |
