Old 09-27-2009, 01:54 AM   #1
Vox DA15 problem
Hey everyone, almost a year ago I re-did my room and lost my power plug. None of the power plugs I have found have worked, is there any way to check that it won't work because it doesn't have the right power plug and it's not just dead?
Also, if it is the power plug, where can I get a new one since none of the ones that I have will work?
Thanks,
Ezro
Ezro is offline   Reply With Quote
Old 09-27-2009, 05:42 PM   #2
Try your power cord on another working device. If the device works then your amp is most likely dead and needs service. It's not likely all your cords are bad.
Twist is offline   Reply With Quote
Old 09-27-2009, 06:32 PM   #3
Well that's the problem, I don't have the actual power cord for the amp, I have a bunch of ones that look like it. My amp says it needs 120v and all these ones are 125-300v.
Old 09-27-2009, 07:06 PM   #4
olddawg's Avatar
Anything that will fit into the power cord jack will work. Most commonly a computer power cord will work fine unless you have something exotic. The voltage rating is just that. If the cord will handle 300v safely then it will certainly handle 127.
olddawg is offline   Reply With Quote
Old 09-27-2009, 07:13 PM   #5
Oh, so my amp is dead then?
Old 09-27-2009, 08:49 PM   #6
Site Janitor
tboy's Avatar
Are you talking about an ordinary simple power cord, or some kind of power-brick thing that came with the amp?
__________________
-tb
tboy is offline   Reply With Quote
Old 09-27-2009, 09:15 PM   #7
I am talking about simple power cords like
Do you think there is anything I can do? Because I am about to go out and buy a new amp.
Old 09-27-2009, 09:21 PM   #8
olddawg's Avatar
You have something wrong with the amp. First check the mains fuse. If you do not have any experience with electronics take it to a tech. You could hurt or kill yourself.
Old 09-28-2009, 10:13 PM   #9
Those power cords are universal, at least for you. if it works on your computer, it will work on your amp. If the amp is dead with the cord, then the amp has further problems inside.
__________________
Enzo is online now   Reply With Quote
Vox AC30TB gain problem rf7 Maintenance, Troubleshooting & Repair 3 04-11-2009 06:03 AM
Vox 847a problem murphcc1 Guitar Effects 1 04-04-2009 01:32 AM
Vox AC-15 Problem Pablomago Maintenance, Troubleshooting & Repair 2 09-16-2008 10:39 PM
Vox AD15VT sound problem roslih Maintenance, Troubleshooting & Repair 6 04-27-2008 05:04 AM
Problem w/Vox Valvetronix AD15VT elixxrx66 Maintenance, Troubleshooting & Repair 0 02-14-2008 06:48 PM
