Old 09-27-2009, 06:07 AM   #1
Marshall VS100 - high pitched squeel
My Marshall VS100 head has a problem...
Here are the symptoms;
Clean channel is fine, although it does have a slight hum at high volumes. When I run the overdrive channels there is a load squeel when the volume is above 1. With the volume below 1 the sound is great (there is a load buzz), but when I try to play at higher volumes there is a real bad feedback type sound. This happens in both overdrive channels but not in the clean channel.
I have tried to replace the tube and it is the same problem. I've tried different guitars, speaker cabs, cables and it is the same problem.
I have also tried to plug the guitar into the effects loop and there is no squeel at high volumes when in the overdrive channels, although there is very little overdrive also.
One note: When I got the amp I had to resolder the main power switch. It was not turning on so I resoldered it.
NovTech is offline   Reply With Quote
Old 09-29-2009, 06:52 PM   #2
Anyone have any ideas on this??? It is driving me crazy trying to figure this out...
Old 10-01-2009, 11:39 PM   #3
Sorry, I meant to say LOUD not load in my explanation...it was late when I posted this...
Old 10-02-2009, 03:48 AM   #4
Check that control. Is the solder to it 100% or are there cracks? Also important, make sure the control is not cracked or open.
__________________
Old 10-02-2009, 05:24 PM   #5
By control do you mean the on/off switch that I resoldered???
Old 10-03-2009, 05:09 AM   #6
No.
I mean volume control.
COntrol = pot = potentiometer
__________________
Old 10-03-2009, 06:38 AM   #7
Problem Solved....
After resoldering most of the board...the noise was still there...
I then tried a different cable from my head to my cab and the noise was gone....grrrrrrrr, i tried different patch cables and they all made the noise, then I used a cable that is made for the connection from the head to a cab and wala...problem solved.
Thanks to everyone for their help...
Old 10-03-2009, 08:07 AM   #8
Supporting Member
gbono's Avatar
Quote:
Originally Posted by NovTech View Post
Problem Solved....
do not use a shielded cable, normally used for low level audo signals, to connect an amplifier to a speaker enclosure. you probably had an oscillation(good for you that you can still hear high frequencies) set up in the output of your amplifier - this situation can damage components.
gbono is offline   Reply With Quote
Old 10-03-2009, 02:04 PM   #9
That is why they make speaker cables and signal cables. Each use has its own needs.
__________________
Tags
100, feedback, marshall, problem, squeel, troubleshooting, valvestate
High pitched noise from my SOVTEK MIG100 adamo Music Electronics 2 10-15-2009 06:21 AM
High-Pitched Squealing at High Volumes harry Maintenance, Troubleshooting & Repair 19 04-07-2009 09:44 AM
marshall VS265 - high pitched noised at high volumes littlered Maintenance, Troubleshooting & Repair 1 02-23-2009 10:10 PM
High-pitched piping whistle in C30 tubeswell Maintenance, Troubleshooting & Repair 8 07-23-2007 03:36 AM
Looking for Marshall VS100 schematic methodofcontrol Maintenance, Troubleshooting & Repair 5 06-27-2007 12:11 AM
