| | #1 |
| Senior Member Join Date: Jun 2007
| Boogie Mark I reissue intermittent
Hey all, This amp is cutting out while being played. When it cuts out there is NO sound or hum or anything. I investigated the speaker jack and it seemed that I could get it to cut out by jiggling the speaker cable. So I replaced the speaker jack and the problem persists. I then tried another speaker cable and speaker and it still happens. I also thought it may be the plug on the amps speaker cable so I replaced that w/ a new one. Problem's still there. I've poked around the amp thoroughly w/ a chop stick moving things around w/ no cutting out. It only cuts out when I toy w/ the speaker jack. I've tested grounds on the speaker jack w/ a meter and can't find any issues there. I even cleaned out the fx send/return jacks, though I didn't find that they had any impact on the issue. I'm stumped on this one. It even seems as if I alligator clip the "hot" of the speaker plug to the jack's "hot" while it is plugged in that it fixes the issue... |
| | #2 |
Sure sounds like a jack to me. Especially after the clip wire.
| | #3 |
Ok so ANOTHER new jack and problem persists... yet alligator clip fixes it still. |
| | #4 |
found it! The speaker.... the internal speaker wires from the terminals to the cone. One of them is intermittent, thus when I alligator clip it must've made just enough of a teeny crackle that it make the cone move and reconnected the wiring, then if I touched that wire w/ my hand I could get it to cut in and out... phew. Hope this saves someone else some time.
| | #5 |
We call that the "tinsel wire."
| | #6 |
tinsel wire... makes me wanna watch Die Hard.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Mesa Boogie Mark IIB bias install | Xavier | Mods & Tweeks | 2 | 07-21-2009 02:04 AM |
| Intermittent Red-Plating | lowell | Guitar Amps | 4 | 03-24-2009 05:54 PM |
| Mesa Boogie Mark 3 Gain Loss | sixstring63 | Maintenance, Troubleshooting & Repair | 34 | 12-12-2008 02:15 AM |
| Mesa Boogie Mark IIC | Boulder Bob | Guitar Amps | 4 | 08-08-2006 05:27 AM |
| intermittent problem on a deluxe reverb | kaiomenos | Maintenance, Troubleshooting & Repair | 3 | 07-06-2006 04:15 AM |
