Go Back   Music Electronics Forum > Instrumentation > Guitar Tech
Old 10-01-2009, 03:17 PM   #1
stratocaster tone and volume control issue
hi there,
i recently purchased new american standard. the guitar's sound is great, though i think i have a small problem with the volume and tone control buttons:
i reach the maximum volume of the guitar with a very slight turn ( turning to 3 reaches the max, and then there is no meaning of continuing turning. ) - some kind of sensetivity problem with the controller ?
same issue with the 2 tone controllers.
i'll be happy if someone can help my figure this out
10x
yairb17 is offline   Reply With Quote
Old 10-02-2009, 06:30 PM   #2
That might actually be deliberate. Although it might not be part of your style, many players use their little finger on the volume pot to produce volume swells as they pick. This is most easily done when the transition from full-off to full-on is produced over a short part of the control's rotation.
Similarly, some players use their little finger on tone controls to produce "pinky wah". There, a rapid transition from full mute to full treble produces a sound similar to a wah pedal.
Since both of these are difficult to obtain with most "normal" potentiometers, it is very possible that, as I say, it is deliberately part of the design of what is generally considered to be a higher-end Strat.
Mark Hammer is offline   Reply With Quote
Old 10-03-2009, 03:45 AM   #3
Are you experiencing this while playing with heavy distortion or does it happen with the amp "clean" also???
Chuck
Chuck H is offline   Reply With Quote
Old 10-05-2009, 12:40 PM   #4
Stealth's Avatar
I might be way off on this, but it might be a pot with the wrong taper - a linear or reverse log-tapered pot instead of a standard log pot. Can you take a look at the pot casing and read off exactly what it says?
Stealth is offline   Reply With Quote
Fender Strat Tone/Volume Control Issues JoeRocks Guitar Tech 17 10-13-2009 03:24 AM
New Build Bass Control Issue mikeboone Debugging Your Build 12 01-05-2009 01:23 AM
New 5E3 build...Tone Control Issue screamin eagle Debugging Your Build 19 08-29-2008 10:36 PM
5E3 Tone Stack / Volume Control Theory jakejoseph Theory & Design 16 08-06-2008 02:57 PM
5E3 Volume Control Issue cminor9 5 E 3 3 03-24-2008 01:46 AM
