Results 1 to 4 of 4
Thread: guitar amp fx loops
    Jun 2008
    u.k.
    46
    guitar amp fx loops
    I have a Laney AOR head with a send/return fx loop on the back. Whats the best pedal to use in this loop to get the biggest lift in volume for when it comes to playing solos?
    Any advice appreciated thanks.
    Senior Member Guitarist's Avatar
    Jul 2006
    365
    Any clean boost pedal or try an eq. Search "boost pedal shootout" and go from there. ALso, just try the boost after you guitar and save that amp-loop for flanger, delay and reverb.
    Dec 2008
    Wernersville, PA
    5,369
    Sound Boost
    I think you are the correct path.
    If you boost from the effects loop, your desired sound will be more stable.
    If you boost from the front end, you get all kinds of gain things going on.
    For better or worse.
    2,301
    Several companies, including EHX, make what are essentially volume-pot-in-a-box pedals. These let you go from some normal bypassd volume setting to something less than that, as set by the volume control on board. Unless you absolutely need extra "push" for your signal, the other approach you can take is to simply stick a preset volume pot in the send/receive loop such that when you engage the loop it turns you down, rather than turning you up. Same net effect, and it is hard to get any purer and simpler than a single passive pot..
  1. Going in loops about grounds
    By mbratch in forum Tweed Builders
    Last Post: 04-21-2009, 12:39 AM
  2. B-52 effects loops
    By DropKick74 in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-20-2009, 02:33 AM
  3. DIY a deluxe power supply for guitar fx pedals?
    By mike_mccue in forum Music Electronics
    Last Post: 07-18-2008, 05:19 PM
  4. The Ultimate Guitar Amp and FX System Ever Made- StompIO
    By Starr Ackerman in forum Flea Market
    Last Post: 02-06-2008, 11:43 PM
  5. Input or FX Return on AMP
    By zikaj in forum Guitar Effects
    Last Post: 04-05-2007, 04:55 AM
