| | #1 |
| Member Join Date: Oct 2009
| First build completed - 5e3 - cathode current issue
Hi all, I have enjoyed my first experience building an amp. Although, I have a question in regard to the 6v6 cathode current. I have toke these measurements with a bias probe: 40.4Ma and 40.7ma on V3 and V4 with a 250ohm resistor 6v6 pin 3=326V X 0.040= 13w 37.6MA and 37.9Ma on V3 and V4 with a 270ohm resistor 6v6 pin 3=326v X 0.037=12w Are any of these cathode currents power tubes friendly? Thanks a lot! Below are a few pics of my home build: ![]() ![]() ![]() ![]() ![]() Last edited by tweed; 10-06-2009 at 03:49 PM. Reason: more info |
| | #2 |
| Supporting Member Join Date: Feb 2007 Location: Wellington NZ
Hi there In order to verify the tube's idle current, what is needed is the plate-to-cathode voltage of each respective tube, and the voltage across the cathode resistor, as well as the actual accurately-measured resistance of the cathode resistor. Without this we can't say for sure what power the tube is dissipating. Furthermore, without knowing what the screen current draw is of each tube, we can't work out the plate dissipation at idle is if we are merely looking at the total tube current draw on each tube (Tube current = Plate current + Screen current). What method did you use to measure the current that you have specified?
__________________ Building a better world (one tube amp at a time) |
| | #3 |
In most cases a 250ohm cathode resistor will be OK up to plate (to ground) voltages of <380vdc, you seem to have less than that, as long as you are 40mA, or less you are OK. The 270ohm looks ideal.
| | #4 |
Hi there, Thanks for the replies. I have used a bias probe plugged between tube and socket. This probe has a 1 Ohm shunt resistor which works as a simple current-to-voltage converter. As per instructions, 40mV multimeter reading corresponds to 40mA tube current. I read a lot of things and at this pois I don't have a clear idea how to determine a good bias point... |
| | #5 |
"I read a lot of things and at this pois I don't have a clear idea how to determine a good bias point..." for you're amp, as long as plate to ground voltage is <380vdc, 35-40mA is a good bias point. General 'rule of thumb' is bias to 80-90% plate dissipation for cathode biased amps, like 5E3. Fixed bias amps might be biased to 50-70% dissipation. However as with most general rules, there are exceptions, that's where experience comes in. Some 5E3 run more like 14W dissipation, some late models run more than that & should really be fitted with a larger cathode resistor. If you had concerns about plate dissipation and your amp ate tubes, or the metal plates glow red/orange, you could try 300-330ohms for the cathode resistor (not that you need to do this, unless perhaps you were trying a stiffer rectifier like 5V4). SF Champs run their 6V6 at 150% plate dissipation. As Tubeswell says, there will be some screen current in that 40.4mA, but this will be negligible (a couple of mA). At the end of the day, biasing is more about tone that meeting mathematical perameters (as long as you're not burning things up that is)...IF you liked your cathode biased amp at 70% dissipation then that would be right for YOU. I wouldn't really recommend less than 30mA for your 5E3 as tone may become thin/sterile, plate voltage would also be pushed higher than what is deemed "classic" 5E3 voltage. One of the benefits of cathode bias is that, if your voltages are suitable (yours are), it's pretty much a case of "fit & forget". |
| | #6 | ||
| Quote:
Quote:
Cement/wirewound/power resistors hardly ever come off the production line all measuring the 'stated' resistance. Get a handful of 5W or 10W power resistors and measure their resistances. You can substitute them into your amp to tweak the bias point. Whilst the difference between a '270R' resistor that actually measures 255R, and another '270R' resistor that measures 265R will not be much in terms of setting the bias point, the difference will be a bit more noticeable compared to a '270R' resistor that actually measures 295R, and so on. The bias voltage is a reflection of the resistance and the current through the resistor (Volts = Amps x Ohms). So you measure the idle DC voltage between the cathode and the ground (with the amp on and the tubes plugged in), and you divide that by the actual measured resistance of the resistor (which you have already measured with the cathode bypass cap disconnected/unsoldered - if you try to measure it with the cap connected, the R-meter reading will be affected by the paralleled series-resistance of the cap) and you get the tube current. Of course if you are measuring the tube current this way with a shared cathode resistor, the current being drawn through the resistor will be flowing through both tubes in parallel, so you will have to divide the resultant calculated current by 2 to get the estimated tube current per tube. As has already been mentioned, you need to deduct the screen current from the tube current to obtain the estimated plate current, which you need for determining actual plate dissipation. The plate dissipation is then obtained by multiplying the plate-to-cathode DC voltage (at idle) with the estimated plate current. (Hence you want to know the cathode DC voltage at idle in order to calculate the plate-to-cathode voltage). But the way you have measured tube current with your bias-probe is giving you an accurate reading of the tube current per-tube. (In this regard I assume your bias-probe is measuring tube current, which it will be if the 1R resistor is in series with the cathode (Pin 8). If it was in series with the plate (Pin 3) it would measure plate-current equivalent in mV - which is important for calculating dissipation. Likewise if the 1R was in series with the screen (Pin 4) you'd get the screen-current equivalent in mV. However if the bias probe resistor it is a poxy little 1% 0.6W metal film resistor, its breakdown voltage is something like 360V, so the manufacturer is probably unlikely to wire it to the plate pin or the screen pin, hence you will have to deduct screen current from the measured tube current to obtain the plate current, as has already been mentioned) There is another way of measuring plate current - by measuring the voltage dropped through the OT primaries, after you have measured the DC resistance of each side of the OT primary. However that method is riskier because the voltages are a lot higher. As for calculating the bias point in a more technical way, Merlin B has a couple of good articles on the Valve Wizard site on designing output stages (including working with tube characteristics charts). As rule of thumb goes, if your amp sounds good and the tubes aren't red-plating, then it should be fine as MWJB already mentioned.
__________________ Building a better world (one tube amp at a time) | ||
| | #7 |
Very Enlightening, thank you for your time guys.
| | #8 |
| Supporting Member Join Date: May 2006 Location: Texas USA
Nobody mentioned it but you wiring is very neat and lead dress is excellent.
__________________ WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personel. |
| | #9 | |
| Quote:
I was by first build I arrived yesterday to the vintage electronics world. I am happy with the result. I tried to make it nice Aesthetically, I wish I have more technical knowledge to fully understand the circuits. I found out that build amps can be very addictive, unfortunately this hobby is a bit expensive. Best | |
| | #10 |
| Member Join Date: Feb 2009 Location: SF Bay Area
I'll second Loudthud's remark. very nice job with this build. Is that locktite on the socket mounting nut's? Again, nice job. I like the tele too. RD
| | #11 |
| | #12 |
Hi again, Yesterday I have took final voltage readings on my amp. My bias probe shows me now 38ma with a 270ohms cathode resistor. What do you think, considering the voltages below? 5Y3 Pin 2: 388V Pin 8: 388V 6V6's Pin 3: 383V Pin 4: 340V Pin 8: 20V Pin 3 to Pin 8: 360V 12ax7 Pin 1: 157V Pin 6: 158 V 12ay7 Pin 1: 116V Pin 6: 176V |
| | #13 |
Looks fine.
| | #14 |
Thanks! this is the way it sound, half blast with a 97 Gibson Studio DC, straight in... |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| New 5e3 build | Robert Heym | 5 E 3 | 2 | 04-06-2009 04:55 PM |
| My 5e3 build | dobsont | Tweed Builders | 4 | 03-03-2008 07:25 PM |
| Mission 5E3 completed | n5oet3h | 5 E 3 | 15 | 10-22-2007 01:43 AM |
| first build completed -thanks to all! | pbreyfogle | 5 E 3 | 4 | 06-30-2007 06:09 AM |
