Go Back   Music Electronics Forum > Instrumentation > Guitar Tech > Pickup Makers
Old 10-06-2009, 01:53 AM   #1
noobie queston about humbuckers
i just wound a stewmac bucker kit i used 44 gauge wire. i decided on 6800 turns per bobbin,the first bobbin read 8 k the second 7.3 k i was thinking it might of shorted out. i was thinking the tension was pretty much the same,after winding the second bobbin the first on read 7.7 k does taping lower the resistance.I'm not sure if i should rewind the lower bobbin or try it
copperheadroads is offline   Reply With Quote
Old 10-06-2009, 02:47 AM   #2
SJE
Resistance, Taping, potting . . . all will have an effect on the reading.
44 is a thin wire so even though you think you are keeping tension the same it's very hard to tell. The other question is why would you think it shorted out? Did you have a break and join it? If it was run straight on without any breakage I can't see any reason why it would short.
Oh just as an example - my last humbucker started out reading around 17k but by the time it had been potted and taped it was nearer 16k . . .
SJE is offline   Reply With Quote
Old 10-06-2009, 03:17 AM   #3
Supporting Member
belwar's Avatar
Quote:
If you're potting it, leave it. That's a nice offset between the coils. You may find your reading changes. Did you measure right after winding?
belwar is offline   Reply With Quote
Old 10-06-2009, 03:28 AM   #4
yes just after winding
potting humbuckers.... Possum Pickup Makers 24 09-17-2009 03:04 PM
Lacquer Queston Norcal_GIT_r Pickup Makers 14 12-15-2008 12:41 AM
Bartolini humbuckers. Possum Pickup Makers 46 07-05-2008 12:32 PM
Humbuckers... well, duuuh... R.G. Pickup Makers 17 09-15-2007 02:22 AM
making humbuckers franklin01 Pickup Makers 6 08-18-2006 06:12 PM
