| | #1 |
| Junior Member Join Date: Oct 2009
Hello all! I have a cheap Squier Strat that I picked up for my kid. Here's what's going on: guitar is working fine except that the bottom tone knob is not working when the switch is in the bridge position. Both tone knobs work where there are supposed, except for the bridge. Any ideas? Do I need to replace the switch? I don't imagine it would be the pot since it is working in the middle and middle/bridge positions. Any help would be great! Thanks!
| | #2 |
| Pickup Maker Join Date: May 2006 Location: Montclair, NJ
Strats don't have the tone knob wired up to the bridge pickup. That's the way they are designed. You have a neck tone, and a middle tone, and no bridge tone control. |
| | #3 |
| Senior Member Join Date: Apr 2008 Location: Oceanside, NY
Like David said, BUT..... all you need is a little jumper to make the middle tone control work for the bridge pickup as well, a common mod. It DOES take some of the "zing" out of the bridge pickup though, that famous raw edge-of-madness tone that the Strat bridge pickup is famous for.
| | #4 |
| Supporting Member Join Date: Jun 2008 Location: Italy
What David and John said. As a footnote to John's post, instead of a jumper, I would advise you to use a switch, so that the mod John suggested is reversible and you can use the tone knob when you need it and go back to the "stock" wiring ( and sound ) when you don't. Hope this helps Best regards Bob
__________________ Foolproof equipment is hard to design, because fools are VERY ingenious... |
| | #5 | |
| Quote:
| | #6 |
That'll make your fillings fall out! |
| | #7 |
| Senior Member Join Date: May 2007 Location: pacific north west
Well hell, if we're gonna modify... I have a mod wiring that changes to a single master tone. The other tone knob hole is used for a switch. The new wiring allows for all the stock strat tones + all three pickups in series with the middle out of phase. It's a badass tone that implies "humbucker" only better. You need to change to a Tele type three pos switch, and the setting are: 1) bridge, middle, neck, series w/middle out of phase 2) middle, neck parallel in phase 3) neck New switch 2) 1) bridge 2) bridge, middle parallel in phase 3) middle It's a great rig. Like having a strat with a special hard rock option. Chuck |
| | #8 |
One thing about a Strat: there are nearly infinite ways to wire it. We have Super Switch, Mega Switch, push-pull pots, push-push pots (I get them from Yamaha; it's like a push-pull but works like a ballpoint pen), toggle switches, rotary switches..... you can do nearly ANYTHING you want with the right switches and three pickups, and like many of us, keep doing it all over again...and again...and again..... |
| Bookmarks |
| Tags |
| pot, strat, tone |
| Thread Tools | |
| Display Modes | |
| Peavey 6505+ Lead channel....tone controls not working? | acorkos | Maintenance, Troubleshooting & Repair | 9 | 09-14-2009 04:39 PM |
| Need help wiring tone pot and ground. | Bmxbarspin724 | Music Electronics | 9 | 11-17-2008 08:15 PM |
| Volumen pot position in cathode follower design | chocopower | Theory & Design | 5 | 06-10-2008 08:59 PM |
| tone control not working | leftside | Maintenance, Troubleshooting & Repair | 5 | 09-05-2007 01:45 AM |
| Odd behaviour from tone pot | slidincharlie (Carlo P) | Guitar Tech | 2 | 04-25-2007 10:20 PM |
