| | #1 |
| Junior Member Join Date: Aug 2008 Location: nola
| baffle board size
redoing a couple fender cabs that stewed in katrina water - not a restore really just a redo, not worried about correctness, just function - baffle boards for these - both are either black or sliverface period - do i understand they used particle baffles on these ? - what was the thickness for a 2-10 possible vibroverb, for a 4-10 possible concert type - not really a fan of particle, thinking of going with the baltic birch - would 1/2" baffle work for these or do i need to go thicker? - i think the last time i posted anything was on the old site! - thank you - oo3
| | #2 |
| Old Timer Join Date: May 2007 Location: pacific north west
If they are BF era cabs they should have had plywood baffles. 4x10 cabs (like the Bassman and Super Reverb) used 5/16" but there were others that used 3/8". I have used 1/2" marine plywood (actually measures 3/8") with good results. Baltic birch should be great. I have never seen a BF amp with a MDF baffle but I have seen the less expensive SF models (specifically a Vibro Champ) with MDF baffles. I don't know much about the other SF models. But I did look in the back of a SF Twin Reverb that IIRC had a plywood baffle. FWIW a popular mod is to change the baffle on some Fender combo's to a non floating type made of thicker material, like 3/4". It's better for bottom end and gives a more overall solid kind of sound with less acoustics and anti phase from the baffle itself. Chuck |
| | #3 |
thanks for the helpful info - i had searched this site first. but didnt think to search archived forum till after i posted - there is some good info there also - oo3
| | #4 | |
| Senior Hollow State Tech Join Date: May 2006 Location: Denver, Colorado
| Quote:
The question about high density particle board baffles is open and I'm not arguing it ... I think most all of them were in fact particle board during and after the black face or silver face era and an odd thickness of about <5/8", plus, (with respect to the full floating black face baffle boards) the 1/4" plywood strips to hold the grille cloth off the actual baffle board. There might have been some super heavy Twins or Super Twins with plywood but (although I can't be sure), I don't think so. Tweed era amps were almost all 5/16" to 3/8" Douglas Fir plywood with the 1/4" plywood strips and used light weight AlNiCo speakers. I have two black face Pro Reverb amps (1965 and 1967), a 1969 silver face Vibrolux and a 1973 silver face Deluxe Reverb in the shop right now and all four, in fact, are using 1/2"-5/8" thick particle board baffles. | |
| | #5 |
"If they are BF era cabs they should have had plywood baffles." O.K... I read that. I have worked on a Super Reverb that had it's baffle changed to 3/4" ply. So I thought it must be correct that the BF amps used plywood. I do know that the 4x10 Bassman baffle info is right though. As I recall Bruce corrected me on a Princeton transformer Q about a year ago. Something else I had read and thought was correct. It's a good thing Bruce is around or who knows what kind of misinformation I might re-print... It's true enough that the only way to really "know" anything is to have experienced it yourself... But, FWIW, I do think plywood is the way to go. As for the 1/4" strips to suspend the grill cloth, that is how I did my last cabinet design and it worked out well. But I prefere my other designs that have a seperate grill on Velcro tabs. Chuck |
| | #6 | |
| Member Join Date: Feb 2009
| Quote:
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| 5E3 baffle mounting Q. | The Captain | Tweed Builders | 3 | 03-27-2009 12:45 AM |
| turret board vs eyelet board | clintonb | Build Your Amp | 5 | 09-22-2007 07:44 PM |
| cabinet/baffle material | Andrei_T | Cabinetry | 8 | 04-01-2007 08:19 AM |
| Tweed Cabinet / Baffle | spiffpeters | Cabinetry | 13 | 01-22-2007 12:03 PM |
| Best place for new baffle? | sparky | Repair and Restoration | 1 | 01-11-2007 11:11 PM |
