Go Back   Music Electronics Forum > Effectification > Guitar Effects
Old 01-01-2007, 07:33 PM   #1
wanna help me figure out how to true-bypass a dean markley overlord?
the bypass on this pedal is so terrible. i'd like to true bypass
it, but i'm unsure on how to rig the pedal up so that the circuit
if always on. i know how to wire a mechanical switch for true bypass,
that parts easy.
but rigging the circuit to always be on after removing the soft switch,
that's where i need some help. i've got a schematic if anyone needs to
see it, let me know. thanks guys.
methodofcontrol is offline   Reply With Quote
Old 01-02-2007, 05:28 PM   #2
Go here: http://www.diystompboxes.com/wiki/in..._AND_SWITCHING
Mark Hammer is offline   Reply With Quote
Old 01-02-2007, 07:34 PM   #3
thanks for the link, mark. but unless i missed something, i know how to true-bypass a pedal w/ a mechanical switch. i understand switch theory and how to wire it all. what i need to figure out is how to replace a momentary soft-switch w/ a true-bypass hard switch, which that article doesn't seem to cover.
the overlord uses a momentary soft switch to ground a point on the board to turn the pedal on or off. the point on the board is only grounded when the switch is depressed. so it's not as easy as, "when this point is grounded, the pedal is on".
i've heard there's a FET involved w/ the switching. but after some continuity tests, i can't conclusively figure out how to ground or jumper the FET to keep the circuit on. if i could keep the circuit on all the time, i could route the signal through or around the circuit via the switch which would give me true bypass. then i'd simply have to rewire the LED through the switch, (which would probably mean cutting a trace or two) and i'd be done.
anyone have any more advice? thanks again.
Old 01-03-2007, 09:25 AM   #4
Please do post the schem, maybe we can be of more help then.
Happy new Year!
Luijo is offline   Reply With Quote
Old 01-03-2007, 11:39 AM   #5
Supporting Member
Steve Conner's Avatar
The pedal will use some kind of flip-flop to convert the momentary switch electronically to a toggle action. You need to hack the flip-flop circuit so it's wedged in the "ON" state permanently. If you post a schematic, I can help you out.
Steve Conner is offline   Reply With Quote
Old 01-03-2007, 05:36 PM   #6
Okay. I get it now.
Is it this pedal? http://filters.muziq.be/model/deanmarkley/overlord
If so, then the power supply is turned on separately. What sort of switching arrangement is used can be quite different. The manual for the pedal (http://www.deanmarkley.com/Info/Lega...uals/D1020.pdf) indicates that it uses a momentary switch, which indicates a flip-flop somewhere in there, as Steve suggests. Of course, what that flip-flop does is another matter. It could actuate a relay (and wall power makes this a possibility), it could actuate a CMOS switch, or it could do the "Boss thing" and actuate some JFETs. Hard to tell from here. I guess what we need is more info about the parts in it. Doesn't necessarily have to be a full schematic, just something that provides some idea of what exactly is doing the switching in an electronic sense.
E.g., are there any 14 or 16-pin chips in there that have a CD or MC prefix or a number starting with 40 or 140? Are there any transistors in there with a K or BF in the part number? Is there anything that doesn't look at all like a chip (i.e., a relay)?
Old 01-04-2007, 04:35 AM   #7
ok everybody, here's a schematic. i hope the quality is good enough.
steve - i believe you are correct. the flip-flop needs to be hacked. that's what i can't figure out. i need to make the pedal permanantly "on", and use the new 3PDT switch i'm installing to route the input signal through the circuit or straight to the output jack. everything aside from hacking the flip-flop i have covered.
mark - that is the correct pedal you linked to. as mentioned above, i need to hack the flip-flop. there is one FET in the pedal which i believe to be the area needing attention. all i've done so far is turned the pedal on and measured every pin of the FET for continuity to ground and continuity to another leg of the FET. i compared that info to the same measurements taken w/ the pedal off. (by "on" and "off" i mean "not bypassed" or "bypassed"...i'm not talking about the power switch.)
the tests i did proved nothing. i was hoping for a simple, "jump this" or "ground that". any thoughts?
BTW...my copy of this schem is a photocopy of someone's photocopy. at some point the two LED's were highlighted, and of course on my copy that appears as a greyish/blackish area...which of course means it appears completely blacked out in the scan. the blacked out part near p7 of IC2 is just the green LED. (bypassed or not bypassed). the blacked out part between the transformer and the tube is the red LED. (power "on").
Old 01-04-2007, 09:50 AM   #8
Seems to me that all you have to do is remove Q1 and Q2. The pedal is always on, the signal gets routed differently depending on wether it is bypassed or not. By removing the Q's you're forcing the signal to go just the "effected" way. So all you have to do is make the"effected" path switchable with a 3PDT and wire the bypass LED accordingly. I hope this makes sense to you.
But please expect confirmation from Mark and Steve, just to be on the safe side, before you do any work on it.
This pedal seems like a copy/license of the B.K. Butler pedals.
Old 01-04-2007, 06:58 PM   #9
The schematic shows the following. In one "state", Q2 goes low-resistance, which means that the gain of the inverting stage where the Drive control is is reduced to essentially zero. At the same time, Q1 also goes low resistance, meaning that there is a low-resistance path from the C3/R3/R4 junction to output resistor R11. When the state is reversed, the resistance of Q2 goes high and is in parallel with VR4, setting the gain (Drive) of that stage. At the same time, Q1 also goes high resistance, placing a very high-resistance path for the "clean" signal to get through to the output.
So, it disables the effect by dropping the tubes' input signal down to nil, and allowing muchmuch more of the clean signal to reach the output. I can see why this is something you'd prefer to truly bypass, since any residual hiss from the tube side of things is always mixed in to the output. I don't know how noisy the tube side is, but whatever noise IS there, you're likely gonna hear it.
To have a true bypass of the circuit, you would do the following:
1) Unsolder Q1 and just yank it right out of there OR, take your utility knife and cut the trace between R2/R4 and the FET.
2) Take Q2 right out of there.
3) Wire up a stompswitch with C1 going to the switch's input lug and R12 going to the output.
Note that since the Overlord assumed that all switching would be done within the circuit/pedal, there is no terminating resistor on input cap C1. This will result in audible popping when your switch is installed. To eliminate popping, stick a 1M resistor from the "free" end of C1 to ground.
There are, apparently, better and worse ways of wiring up the heater in the tube, which can impact on how much hum isproduced. I can't tell from the drawing whether this has been taken advantage of or not.
If you rotate the drawing 90 degrees clockwise, you'll see there is a strong resemblance between the the tone control arrangement and the standard Fender/Marshall tonestack. Should you wish to tailor the tone control to your own particular needs, I suggest that you take a look at on-ine resources regarding those two tonestacks, and also at the online Duncan Tonestack calculator.
Thanks for scoring the schem. Another one to add to the stack!
Old 01-05-2007, 12:51 AM   #10
so mark...all i have to do is remove Q1 and Q2? and the pedal will be permanently "on"?
that seems too easy. i thought for sure i would have to jumper something.
as for the green LED, i'll just lift the (-) and route it to the switch w/ a limiting resistor to ground.
the schematic was hard to find. i found a guy online who scored it a few years back from someone HE found online. and up until i scanned and posted it, it was strictly a paper transaction. i got my copy of a copy through the mail. hopefully it will be easy to find online now for anyone who may be looking.
Old 01-05-2007, 04:00 PM   #11
Sounds like win-win for everyone. And yes, removing the two FETs makes it permanently "on". Since I could not see anything in the scheme that looked like a flip-flop, you can satisfy my curiosity by telling me if the stock footswitch is a (nonclicking) momentary or is a latching/clicking SPST like some sort of table lamp switch.
Old 01-05-2007, 11:46 PM   #12
hey mark, the stock switch is a non-clicking momentary. thanks for the help, i'll try to mod the pedal this evening and post results.
Old 01-07-2007, 12:18 AM   #13
hey mark...i removed Q1. there is no Q2.
if you look more closely at the schem, (as i should have) you can see that the three pins of Q1 (marked, "S", "D", and "G") are labled as such:
in the upper part of the schematic, "D" is on the left and in the lower part of the schem "D" is on the right.
"S" is on the right in the upper part, but on the left in the lower part.
"G" is in the middle on both drawings.
anyway...i removed the FET, but the pedal switches exactly as it used to. i haven't listened to the pedal since removing the FET. i wonder if the gain will be different now?
i'm going to try jumpering SW2.(momentary switch) it's in between pin 7 and pin 6 of IC2. R8 comes off pin 6 to the switch, and R9 comes off pn 7 to the switch.
let me know if you have any other ideas. thanks again.
Old 01-07-2007, 08:22 AM   #14
The orientation of the S and D of an FET used in this way doesn't matter at all. It's like water going through a pipe, it will always go through no matter which end you feed it.
What I'm thinking is that maybe you don't have the right schem. It's either other pedal or a diff revision of the same pedal.
According to your schem there should be a second Q somewhere.
As I said in a previous post, this pedal looks like a copy/license of the B.K. Butler pedals, so there is a possibility that a schem for one of his pedals will match yours.
Old 01-08-2007, 03:58 AM   #15
no...i dont think so. what i was saying is that my pedal only has ONE fet. and the schematic i posted also only has ONE fet. it's just drawn twice to show how it's hooked up to each IC. the fact that there is a reference letter "A" to show that those parts are connected and it was drawn in after the fact let's you know that my schem is obviously a photocopy. i haven't traced the circuit out entirely, but it looks correct to me w/ the pedal in front of me everything has checked out so far.
Old 01-08-2007, 08:57 AM   #16
Nope, sorry to disagree with you, but if you examine your schem closely you clearly see a Q1 AND a Q2 (they are diff FETs, one is a 2SK30A and the other a 2N4383, but the numbres are not very clear). The connection you see between them ( A ) is there to show you they share a common connection for their control signal, nothing else, so they work at once. The opamps are 4558, dual opamps and all four stages are being used, two in the switching and two in the signal path. The first stage of the 4558 involved in the signal proccesing is just a buffer while the second stage provides the actual distortion, which is then smoothed out by the valve following it.
Mark's explanation of the roles of each "Q" is dead on right so if everything else is correct there must be a second FET hiding in there somewhere or the schem must be of a different pedal. The fact that so far the schem matches your pedal (though you admit not tracing it completely) just reinforces the fact that there must be another FET somewhere.
Old 01-09-2007, 04:54 AM   #17
there is DEFINATELY only one FET on this board. it is a "K30A" as written on the FET itself. i see that the "second" FET is labled as a 2N4383.....but "Q1" is written next to both drawings. someone was obviously confused when drawing this up. in any case...there is only one FET. i have removed it. but the pedal still switches as it used to. it is not in a constant state of "on". any other suggestions? i will try to trace the pedal out to confirm the schematic next time i have an hour free. but i will certainly entertain any questions or advice in the meantime.
Old 01-09-2007, 03:20 PM   #18
Supporting Member
There must be a second FET in there somewhere! :-0 As I understand it, one of them lets the clean signal pass to the output while the other one (the lower one squeezed into the schematic) shuts off the distortion stage by giving it lots of negative feedback. This lowers its gain drastically when the pedal is in clean mode, and stops it buzzing through onto the clean channel.
Anyway, either there's a second FET that you didn't remove, or else you accidentally solder bridged the gate terminal of the FET you did remove to one of the other terminals.
P.S. Cute trick, how they made the flip-flop from two op-amps.
Old 01-10-2007, 01:58 AM   #19
ok... i got to the bottom of this.
to clarify...."yes" there is only ONE FET on the board. i'm certain of this. there's
only so many places a componant can hide on a 3"x2" circuit board.
to my own embarassment, i wasn't listening to the pedal after i removed the FET, i was only using a dummy plug and watching the LED come on and off w/ the switch. the fact is...removing the FET did put the circuit in a permanent "on" position. the green LED, however still turns on and off w/ the momentary switch.
i had it in my head that the FET also controlled the LED. so the fact that the LED still went on and off made me believe the circuit was doing the same. sorry guys. i will be wiring up my true bypass switch tonight or tomorrow. the tone controls suck on this pedal, i may be modding them as well. i'll post my questions/observations/progress. thanks again for the help.
Old 01-11-2007, 10:06 PM   #20
First off, kudos to you for your humility. Looks good on you, man.
Second, glad you sussed it out. I'm still kinda mystified about how DM is able to accomplish switching with but a single FET but so be it.
You might want to tinker with the Duncan Tone Stack calculator - http://www.duncanamps.com/tsc/ - and figure out what sorts of mods you might want to do to the Overlord tonestack. Give us a sense of what kinds of tonal tricks you need it to do and perhaps we can suggest some mods and component values.
Old 03-08-2007, 12:35 PM   #21
Hello!!
I bought a Overload last week and IT HAVE TWO FET.
So.... if i a want to change it to true bypass..... Should i cut them???
chocopower is offline   Reply With Quote
Old 03-08-2007, 04:02 PM   #22
simply removing the FET's does not make your pedal true-bypass. removing the FETs should make the switching mechanism obsolete, so your pedal will always be "on". this is the first step to true-bypass'ing a pedal. do you know how to wire up a 3PDT switch for true-bypass? if so...you should have all of the info you need. if not...i can show you how to do it.
Old 03-08-2007, 04:42 PM   #23
thanks!!
I´m try to do it my self.
If i have any problem.......i´ll post again.
best regards from spain!!!!!
Old 03-13-2007, 10:44 AM   #24
Hello again!!
I´m thinking in change some value in my Overlord tonestack for more mid definition and more controlable treble...
This is the tonestack. I need help to identify all the conponents to translate them to the Duncan´s Tonestack Calculator
C9: TREBLE CAP
C10: BASS CAP
C11: ¿?¿?¿?¿
C12: MID CAP
Is this correct?
If i up tha value of R16 i supouse it get down total gain.....¿?¿?¿
best regards fron Spain
Old 03-20-2007, 04:03 PM   #25
Hi again!
Comparing and Overlord and a Chandler tube drive.... i saw the Overlord have 2 JRC4558 chip and the Chandler just one.
I asume this make the Overlord more "High-gain"...
Are there any way to make switchable one of the chips in the Overlord?
Regards!!
Is this too good to be true? jaydawg Tubes (Valves) 12 01-20-2008 12:16 AM
SmolskiTech True Bypass Loop SmolskiTech Flea Market 4 09-13-2006 10:36 PM
