Go Back   Music Electronics Forum > Amplification > Guitar Amps > Build Your Amp
Old 10-10-2009, 11:06 PM   #1
DIY control labeling?
One of the hardest things for me in a DIY build is trying to label the controls so that the build doesn't look homemade. I'm great with a soldering iron, but when it comes to graphics, I run in fear. I used to get "Needs Improvement" on my handwriting legibility back in elementary school.
On my current project, I need to label four knobs: Volume, Treble, Bass, and Reverb. I've even thought of ordering a Mojotone guitar amp faceplate and cutting out that section, though that seems a bit expensive.
Any great ideas for how to do this for the graphically challenged?
Rhodesplyr is offline   Reply With Quote
Old 10-10-2009, 11:46 PM   #2
Any office supply store like Staples will have label makers. These are typically little hand held gadgets that print out lettering on a tape. You can then transfer the lettering from the tape to your panel. I don;t know a lot about them, my wife used one for certain projects for a while. I know Brother is a large brand, makes many models, but I am sure there are other brands.
ANother idea is to print out a panel using your computer. Glue the printed sheet to your panel, then mount a sheet of clear plexi over it for protection.
__________________
Enzo is online now   Reply With Quote
Old 10-13-2009, 01:33 AM   #3
Supporting Member
Another idea is lazertran,
Transfer papers for artists - Lazertran
which you can get from most decent art supply shops. You design the graphics on your computer and print it out on your laser printer or inkjet (there are different types of lazertran for each) and then depending you put the decals on your chassis and clearkote spray/lacquer over the top of them, or use the stuff where you apply it to the metal and bake it in an oven for a wee while.
__________________
Old 10-13-2009, 02:59 AM   #4
Oh yes, forgot all about making decals, and I am into model railroading where we do that all the time.
__________________
Old 10-15-2009, 06:46 AM   #5
zhyla's Avatar
Yeah, printable decals are pretty easy to work with and turn out well enough. I used the laser printable variety for the below project. Just make sure to reverse your image before printing .
__________________
Check out my signal generator for your iPhone or iPod Touch.
zhyla is offline   Reply With Quote
Old 10-15-2009, 05:32 PM   #6
Supporting Member
Steve Conner's Avatar
It's probably overkill, but I know a guy who runs a CO2 laser cutter/engraver. I designed my artwork in a CAD package and got him to engrave it backwards on clear plexiglass, which I then mounted in front of a matt black faceplate and edge-lit with LEDs. It looks wicked if I do say so myself.
__________________
"Transformerless is the way to go", said he, without a hint of irony.
Steve Conner is offline   Reply With Quote
Old 10-15-2009, 07:04 PM   #7
Supporting Member
Verry coool Steve
__________________
Old 10-30-2009, 06:22 AM   #8
I use a Printshop program (about $12 back way when) ande print stuff on a sticky label. Then coat it with about 7 coats of spray laquer. It creates a very tough surface, and it's shiney too!
booj is offline   Reply With Quote
The Following User Says Thank You to booj For This Useful Post:
Rhodesplyr (10-30-2009)
Old 10-31-2009, 03:47 AM   #9
I used a local laser etching shop - make plaques for awards, trophies, etc..
They required artwork in Corel, Illustrator, even pdf i think. The material is black anodized aluminum with adhesive backing, the laser removes the black anodize revealing the raw aluminum beneath. It should be sprayed with satin clear afterwords - I didn't. I think it cost $13. I drilled the holes.
RudeBoy is offline   Reply With Quote
Old 10-31-2009, 05:10 AM   #10
cminor9's Avatar
hey Rudeboy, I know it's not related (but I do like your faceplate), but I recognize those old hammond xformers (from an AO-35?) They are on a build on my bench as we speak. Building a 15w pp el84 amp (as I suspect yours is) and I wonder if the OT is up to the task. How's it sound?
__________________
Shiny package of rusted wreckage
Fender Schematics Galore at http://ampedia.redbeartrading.com
cminor9 is offline   Reply With Quote
Old 10-31-2009, 03:38 PM   #11
Quote:
It is an AO-35 conversion I did for my nephew. It runs 6V6s w/SS rectifier. No feedback, so lots of gain. It is quite chimey and breaks up early. I'd like to hear it with a Celestion Blue sometime.
The Following User Says Thank You to RudeBoy For This Useful Post:
cminor9 (10-31-2009)
Old 10-31-2009, 08:16 PM   #12
tedmich's Avatar
quite pretty build! Doesn't the silver spray paint on the PT/OT conduct a little? Maybe the key to the T0NE!
Steve, typical half assed effort! What happened to the nanotech arranged hummingbird interference crystal / chemiluminescent holographic labels? I won't even bother uploading my sharpie graphics....
tedmich is online now   Reply With Quote
Old 11-03-2009, 06:37 PM   #13
Senior Hollow State Tech
Bruce / Mission Amps's Avatar
Which product do you bake and how does this work with the super hot fuser in the laser printer?
This would be very handy for a few quick builds I could do with blank chassis and not having to deal with my silkscreener and their $120 "set up" fees and min 50 piece runs!
__________________
Bruce
Mission Amps
Denver, CO. 80022
www.missionamps.com
303-955-2412
Bruce / Mission Amps is offline   Reply With Quote
DIY Leslie Speaker Speed Control JKowalski Guitar Effects 3 06-28-2009 12:03 AM
DIY Attenuator sheppadizzle Build Your Amp 0 03-21-2009 02:22 AM
my DIY AC30 nap_alfa55 Build Your Amp 7 12-18-2008 01:00 AM
DIY Tubes R Walker Pickup Makers 10 03-02-2008 05:25 PM
Noise Reduction DIY >not gated< DIY? orson Guitar Tech 8 06-28-2006 10:59 PM
