| | #1 |
| Junior Member Join Date: Oct 2009 Location: Humble, TX
| Need advice on adding an ext speaker cab for 1980 Peavey Mace
I have a 1980 Peavey Mace VTX w/ 2- 12" Black Widows (original spkrs). The manuals are confusing... one Mace manual says I can add a 4 ohm load which would create full 2 ohm power and states the Mace has a 4 ohm output on the orig spkrs. A Mace/Deuce manual states that 8 ohm or 4 ohm loads can be added. My Mace has 1 Main and 1 Aux jack that is labelled 4 ohms. So I'm assuming adding a 4 ohm cabinet is perfect. This would give me 160 watts @ 2 ohms. Can someone recommend a good nowadays 4-12 cab to use and how to rewire since all new cabs seem to be 16 ohm? Thanks! |
| | #2 |
| Senior Member Join Date: Jun 2008
16 ohm 4-12 cabs have 4 16 ohm speakers. They are wired in series - parallel. wire all the speakrs in parallel and the impedance will be 4 ohms. Might want to check the forum for threads concerning wiring speakers.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Ampeg VT40 (top mount) ext. speaker problems | methodofcontrol | Repair and Restoration | 6 | 06-25-2009 02:54 AM |
| 135W Ultralinear Twin Reverb: Questions about wiring in Ext Cab and NFB section | darrellcheng | Theory & Design | 2 | 03-29-2009 03:29 AM |
| Use of Int/Ext Speaker Jacks on Deluxe Reverb? | Mango Moon | Theory & Design | 10 | 11-12-2008 04:41 AM |
| Fender Bassman ext. speaker out | dazzlindino | Theory & Design | 10 | 09-06-2008 05:58 AM |
| Hum when adding a wireless...advice please | Garydean | Guitar Effects | 8 | 06-19-2008 01:50 AM |
