Go Back   Music Electronics Forum > Amplification > Guitar Amps > Vintage Amps
Old 10-13-2009, 02:00 PM   #1
crackling sounds from Selmer TnB 50 R SV
hi,
As I have absolutely no valve experience, I wonder if someone has had any experience with "crackling" sounds from a valve amp? - when you switch over from standby after warm up, there is a loud random crackling; at least one poti is noisy too, but it seems to add to- rather than being the source of the crackling noise...
Any suggestions as to what I might do before approaching (..and paying) a professional?
selmertnb is offline   Reply With Quote
Old 10-13-2009, 03:40 PM   #2
Supporting Member
Steve Conner's Avatar
I had a T'n'B 50 SV that crackled. In my case, it was one of the plate load resistors in the PI beginning to go. But pots, valves and capacitors can also go faulty. I ended up gutting my TnB completely and rebuilding it with fresh components.
If you don't know what "plate load resistors in the PI" are then my advice is take it to a professional.
__________________
"Transformerless is the way to go", said he, without a hint of irony.
Steve Conner is offline   Reply With Quote
Old 10-13-2009, 04:12 PM   #3
of course I don't - but in the end it is a load of metal and carbon pieces soldered together, right? - could I perhaps spray some contact cleaner into the potis (avoiding any thing else) and turn and turn...and perhaps check the setting of the valves and clean contacts etc. or is this unlikely to resove anything?
Tags
crackling, selmer, tnb
Selmer Auto Rhythm alkali Music Electronics 0 06-19-2009 02:27 PM
type/brand transformers in Selmer amps? Chris - CMW amps Vintage Amps 4 02-26-2008 11:57 PM
Hissing and crackling sounds SirChick Maintenance, Troubleshooting & Repair 10 11-14-2007 01:11 PM
Selmer Corvette cap job and tweeks Steve Conner Mods & Tweeks 2 10-31-2007 12:21 AM
Selmer Truvoice TV6 schematic jimi Vintage Amps 2 10-12-2006 08:26 PM
