| | #1 |
| Senior Member Join Date: Jul 2009 Location: Phoenix, AZ
| What Not To Do With Your Tube Amp
I was searching for info on the Crate Stealth GT50 that came up in another thread & I came across this youtube video. Ouch! |
| | #2 |
| Member Join Date: Aug 2007 Location: Portland, OR
So, that's not a feature? |
| | #3 |
| Old Timer Join Date: May 2007 Location: pacific north west
When my amps do that I intentionally crank it up until the offending tube blows up Chuck |
| | #4 |
OK, I'll bite. I've always heard that power tube failure put the output xfmr at risk. What design feature(s) makes you "sure of the rest of the amps ability to handle a tube failure"?
| | #5 |
| Site Janitor |
Thanks, I really enjoyed that.
__________________ -tb |
| | #6 | |
| Senior Member | Quote:
jamie | |
| | #7 |
A failing tube can cause problems for the PT also. For starters, I almost always use a false CT for my heater wind. If anything like a plate to heater short happens the resistors will blow and open the circuit. Having an OT thats able to handle spikes, shorts and off loads is also a good idea. Some builders think that cheesey OT's are part of the tone of certain amps. I think that can be true, but doesn't have to be. I use beefy OT's. Screen grid R's rated carefully can double as fuses that will open if there is a gross failure. I'd rather blow a screen grid R than an OT any day. A rock solid bias supply is a good idea. If anything goes wrong with the bias supply while a tube is failing it can take out the other tubes too. This is substantially more stress to the rest of the amp than one tube failing. Part of the game is knowing what components to over rate and which ones should be rated to intentionally fail if things go grossley bad. Some guys think they're building a reliable amp by over rating ALL the components, but IMHE this is a bad idea. The same conditions that are bad for tubes are often the same as whats bad for the OT. So it may just be more of a coincidence than a fact that blown tubes and OT's seem to go together. I'm speaking specifically of an open load. I would never intentionally run an amp into an open load to blow up a tube. For that matter, I would never intentionally blow up a good functioning tube. But if one is already failing, and all other parameters are in check (no open load), well... It's an observation in curiosity at that point. There are other things like flyback diodes and fusing the B+ rail but I never use them. I've blown up many tubes (and of course some peripheral components) but I haven't lost any transformers... Yet Chuck Edit: I always shut the amp down immediately after the event so that any persistant shorts won't be stressing the amp unchecked. Last edited by Chuck H; 10-15-2009 at 02:58 AM. |
| | #8 |
Thanks, Chuck! My silly post ended up providing some good info!
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Homebuilt Tube Amp Cabinet with modded Pacemaker amp | ScottCr | Build Your Amp | 2 | 09-22-2009 07:11 PM |
| Tube amp addiction, tube amp dyslexia and ECT | tubeswell | Guitar Amps | 19 | 07-29-2009 02:37 AM |
| Converting a stereo tube amp to guitar amp | Rayme | Conversions | 1 | 12-30-2008 07:44 PM |
| B&K Tube Tester & output tube question | Chevy | Maintenance, Troubleshooting & Repair | 8 | 12-13-2008 02:08 PM |
| tube amp problem. loose tube maybe? | bumcharge | Maintenance, Troubleshooting & Repair | 5 | 10-16-2006 02:50 PM |
