Go Back   Music Electronics Forum > Amplification > Other Amps
Old 10-14-2009, 03:06 AM   #1
dom
separate tone for left and right speakers
hello !
would a mixer be the best bet for getting different left and right eq after my preamp ? after the preamp comes a 50:50 mesa.
cheers !
dom
dom is offline   Reply With Quote
Old 10-14-2009, 04:42 AM   #2
Peavey used to make a stereo EQ. I'm sure there are others. Even a pair of single channel EQ's would work. A mixer would "work" but seems limited in it's freq. band control and probably overkill for the job (since most mixers have more than two channels).
It sounds like your intending to run a full stereo rig. There's no reason a stereo EQ or a pair of mono EQ's couldn't be used, other than expense. If you have a "spare" mixer then go ahead and use it. The mixer may also allow for seperate effects buss to each channel which will further expand the stereo effect.
Chuck
Chuck H is offline   Reply With Quote
The Following User Says Thank You to Chuck H For This Useful Post:
dom (10-15-2009)
Old 10-15-2009, 02:45 AM   #3
dom
thanks, chuck !
Yes, chuck ! i just need to add some bass to one side and it should sound just fine. that's one of the reasons why i prefer using 2 combo amps with a dsp/ preamp, instead of a power amp and 2 speakers. but yes, true sound separation ( 2 different air pressures ) is what i'm after.
cheers!
dom
Behringer PMP3000 Left main will not work jackieblack Parking Lot 0 08-18-2009 12:27 PM
Behringer 880S Left Main Cuts out chaddz3 Maintenance, Troubleshooting & Repair 4 05-20-2009 04:10 AM
Left pickups in potting for 2 hours - oops achase4u Pickup Makers 7 03-18-2008 04:33 AM
Separate Cathode Bypass Resistor/Cap per 6V6 greg Theory & Design 13 01-31-2008 10:07 AM
tdog has left the building... tboy Lobby 8 07-17-2006 09:49 PM
