| | #1 |
| Supporting Member Join Date: May 2008
| Transformer for DI box
Does anyone have a favorite transformer to use in a DI box for isolation? I'm working on an FX switcher with multiple outputs and I want to isolate the grounds between amplifiers.
__________________ Clouseau: "I thought you said your dog doesn't bite." Innkeeper: "That's not my dog." |
| | #2 |
I like the Jensen JT-11-YMPC. It's the least expensive in the Jensen line, 1:1, willl fit in a Hammond box, low insertion loss, maximum output of 8dBV is way plenty for guitar signals. Feed it with a FET buffer, and away we go.
| | #3 |
| Senior Member Join Date: Sep 2008
i use the Weber WBALUN transformer.https://taweber.powweb.com/store/balun.jpg they are only a cpl bucks and I usually tack one or two on to my list when I order from them. I used to put them on amps I built that had multiple secondary taps on the OT, but now I've started putting them into my speaker cabs so that no matter what amp I plug one of my speaker in to I have a DI out. I replace R1 in his schemo with a 100k lin pot@ 2W as a coarse adjustment and use the 1kA as a level adjustment. |
| | #4 |
I went there first and missed that one - thanks. It looks pretty robust. Nice size. I wonder about the -2dB at 80 Hz. It might be ideal, actually. I need one of Ted's alnico 12's anyway, so I'll tack one on.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| DI Box with 1:1 600ohm:600ohm Transformer | djembutz | Guitar Effects | 0 | 10-15-2009 05:28 AM |
| pickups by Tony Di Gregorio | StarryNight | Pickup Makers Showcase | 0 | 06-04-2009 11:04 PM |
| DIY amp DI question | GainFreak1984 | Theory & Design | 12 | 10-15-2007 06:02 AM |
| Old DI with Distortion | nwguy | Maintenance, Troubleshooting & Repair | 2 | 07-08-2007 05:27 PM |
| internal DI box | 9 volts | Theory & Design | 0 | 03-17-2007 01:01 PM |
