Go Back   Music Electronics Forum > Instrumentation > Guitar Tech > Pickup Makers > Tools and Coil Winding Gear
Old 10-17-2009, 07:42 AM   #1
Supporting Member
belwar's Avatar
Looking for winder for multiple round coils
Anyone have a recommendation for a automatic coil winder to run multiple coils at a time? I'm producing a pickup with 8 coils per pickup, and two per instrument and want to automate the process... My wishlist is as follows..
3-6 bobbins per shot
Gear based
Automated traverse
upto 42 awg.
I like vintage machines.
I think there is a few meteor machines out there that might work. Does anyone have a recommendation? I'd like to do the least modding possible. I'd love to get my hands on a gorman 2+2 but I doubt that is going to happen.
Heres a picture of the bobbins
belwar is offline   Reply With Quote
Old 10-17-2009, 08:37 AM   #2
You can stick all the bobbins on a shaft and put it between centers on a tailstock winder. You just need a narrow tensioner that you can stack up side by side on your traverse.
I'd think it would be easier to automate the loading and unloading of a single bobbin rather than have to do all that manually to a whole stack of bobbins at once and then repeat it every 6 minutes unless you have two winders going side by side at even intervals.
David King is offline   Reply With Quote
Old 10-17-2009, 04:52 PM   #3
Supporting Member
belwar's Avatar
I plan on winding REALLY fast. The bobbins are not oblong but circular, so I dont have the normal whipping going on. Im sure I can get into the 6-7000 RPM range, maybe more if I slow start up..
Old 10-17-2009, 05:53 PM   #4
Quote:
Originally Posted by belwar View Post
I plan on winding REALLY fast. The bobbins are not oblong but circular, so I don't have the normal whipping going on. I'm sure I can get into the 6-7000 RPM range, maybe more if I slow start up..
And slow stop as well.
Joe Gwinn is offline   Reply With Quote
Old 10-18-2009, 12:46 AM   #5
Why not just sub these coils out to a firm that has the high speed, automated winding equipment? Cine-Mag? I wonder if the bobbins already exist out there too -waiting to be tapped.
Old 10-18-2009, 01:11 AM   #6
Those coils look remarkably similar to ones I was windiing for Hex sustainer research...
(ignore the text - that relates to posting on a UK Engineering forum!)....that's a sewing machine bobbin that I wound copper wire onto!
I've parked the project for the time being, but I had a similar requirement (to wind six bobbins quickly). I'm too tight to sub out (anyway, this is just a hobby for me), so I was going to go bobbinless & wind straight onto the steel core....I even went so far as to get some little jigs made up to allow quick alignment/changing of the parts.
peskywinnets is offline   Reply With Quote
Old 10-18-2009, 02:13 AM   #7
Pickup Maker
David Schwab's Avatar
Quote:
Similar, but with a lot more winds and thinner wire.
David Schwab is offline   Reply With Quote
Old 10-18-2009, 01:13 PM   #8
chevalij's Avatar
I know it doesn't do multiples, but my wife's sewing machine would fill a bobbin like that in about 30 seconds Even traverses nicely !
similar to this
__________________
www.copperheadpickups.com
chevalij is offline   Reply With Quote
Old 10-18-2009, 06:27 PM   #9
Supporting Member
belwar's Avatar
Thats pretty facinating. The traversing probably wouldnt work with magnet wire, but im going to go to my local fabric store and give it a try.. I say this product called "The easy winder" which may work if I can mod it to have a counter, and a better tensioner.
Old 10-18-2009, 07:45 PM   #10
Quote:
similar to this YouTube - Sewing & Fashion Design : How to Wind a Sewing Machine Bobbin
This was how i used to wind round bobbins when i started pickup making a couple of years ago.
I ended up with with multiple coils with only one start and one end wire.
Alabam is offline   Reply With Quote
Old 10-18-2009, 08:47 PM   #11
Supporting Member
This winder cost me around $400. It runs on RC servos. I had it set up to do as many as 8 humbucker bobbins but pared it down to 6 because it was not real stable. But I bet you could do 8 round bobbins easy. Dialing it in was a pain but once done it worked flawlessly.I stopped using it when I got the Leesona 102.
__________________
www.throbak.com
JGundry is offline   Reply With Quote
Old 10-19-2009, 02:27 AM   #12
chevalij's Avatar
There are also winders on ebay specifically for bobbins. Pretty cheap if I remember correctly, and probably easy to modify.
__________________
« Gorman winders | - »
Buying from music-go-round Rayme Music Electronics 3 09-25-2009 02:27 PM
edges: what round over bit? The Captain Cabinetry 8 12-12-2008 11:17 PM
Wind round, then mount on bobbin? pilotjones Pickup Makers 11 03-06-2008 06:01 PM
Vibro King - Round Four mikeboone Maintenance, Troubleshooting & Repair 0 12-11-2007 11:45 PM
Tall coils vs. short coils Biarnel Pickup Makers 1 07-24-2007 04:38 PM
