| | #1 |
| Senior Member Join Date: Apr 2007 Location: Nijmegen, Netherlands
| Any 8X El34 amps here?
I got this old Jamm amp in which has 8x EL34. I don't like the original schematic so I was looking at other schematics on 8x EL34 amps. Can't find any; any help? |
| | #2 |
| Senior Member Join Date: May 2006 Location: Netherlands
Can you show the original schem first ? And some phots of the guts would be nice ; must be a huge OT. |
| | #3 | |
| Quote:
Thing is HUGE! Biggest transformers I've seen; the choke is bigger then most power transformers | |
| | #4 |
| Senior Member Join Date: Apr 2007 Location: sydney australia
what are you trying to achieve by looking at a schematic for an amp with 8 el34's? its just like an amp with 2 but 4 sets of 2. (so double one with 4). its the same circuitry in parrallel. just takes a bigger transformer as you've noticed. sounds like an interesting amp though. |
| | #5 | |
| Quote:
I've worked with these kind of amps before and they all had buffers set between the PI and the powertubes (tube buffers); I just wanted to know if that was nessecary or what designs were used in this......... PICS!!!!! Last edited by Bernardduur; 10-18-2009 at 04:09 PM. | |
| | #6 | |
| Senior Member Join Date: May 2007 Location: Silicon Valley ; USA
| Quote:
__________________ ______________________________________ Gary Moore Moore Amplifiication mooreamps@hotmail.com | |
| | #7 |
OK, so it'll behave just like a normal amp but then just with more tubes. Great! Schematics: PSU Poweramp; only drew 2x EL34 Preamp Last edited by Bernardduur; 10-18-2009 at 07:58 PM. |
| | #8 |
Bernard, Could you post the preamp in a bigger resolution, the values are illegible. So it has a transistor preamp ! Where is the other half of the ecc83 before the PI ? |
| | #9 |
| Senior Member Join Date: Apr 2008 Location: PDX
what a monster! SS preamp and 100w brute watts output...kind of an inverse bedroom amp... not quite what I am looking for but to each there own! |
| | #10 | |
| Quote:
The other half of the ECC83 is not used. The PI tube is an ECC85 tube. No heater on pin 9 on this tube. Why was this done? Is the ECC85 a nice PI tube? | |
| | #11 |
The ecc85 for PI is a good tube it can deliver more current than a ecc83/ 12ax7 and pin 9 is a shield between the two triode halves. I don't know what the function is of those diodes at the front of the preamp . Beats me, can't be clipping can it ? Alf |
| | #12 |
I've seen this kind of clipping before as a method of compression. I'll make a part of the schematic again; clearly I can spot some changes that were made after the PCB was made. Dunno by who |
| | #13 | |
| Quote:
| | #14 | |
| Quote:
For the others, here's how the preamp's input was set up: Picture | |
| | #15 | |
| Quote:
Cheers, Albert PS: I have an old "LAY Power Block" lying around with 10 x EL34 Haven't opened it up yet. IIRC it has an ECC81 LTP inverter. | |
| | #16 |
| Could be! It'll add some compression when the signal gets too hot or even clips it.
| | #17 |
Imho I think this circuit was designed for playing (or passing) a clean signal, so who wants clipping at the front then ? I would remove it . What is the inductance of the choke ? Alf |
| | #18 | |
| Quote:
The signal has to be higher then the threshold of 1.4V to get clipped; in this setting it'll protect the FET. I'd rather use an end to end diode setting with one end to ground, one end to V+ as it is normally done. Can't read inductance here; no Henry on my DMM | |
| | #19 |
Question: I've seen most amps work with simple caps to ground as power supply filtering.... now this amp has bleeder resistors over em. What is the advantage of that? link to pic |
| | #20 |
bleeder resistors discharge the caps after power off so they dont stay at high potential for long periods of time.
| | #21 |
I found in a good source that they are also used as ways to get both caps the same load so not one is quicker then the other. Makes the 'new' value (2 caps in series) more stable. My question is more on the soundwise; how is it compared to the standard cap to ground? I think I'll swap em for 47uF caps as I can get em in the right voltages pretty easy. |
| | #22 |
| Senior Member Join Date: Jul 2007 Location: leighton buzzard, uk
can anyone explain that to me? i've always wondered why. surely two identical capacitors would have the same resistance? is it just because the resistance of the capacitors is low, so resistance in wires etc. would affect the potential divider that's created by the capacitors? |
| | #23 | |
| Quote:
| | #24 |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| RCA 8x-71 | lowell | Music Electronics | 12 | 04-25-2009 12:27 PM |
| EL34 to KT66? | rockon1 | Mods & Tweeks | 5 | 12-23-2008 04:50 PM |
| EL34 vs 6V6 | daz | Theory & Design | 8 | 06-25-2008 08:58 AM |
| Best EL34 reissue? | fuzzman93 | Guitar Amps | 1 | 02-19-2008 04:35 PM |
| EL34 and EL34B help | matatak6 | Guitar Amps | 4 | 02-28-2007 11:59 AM |
