Go Back   Music Electronics Forum > Amplification > Guitar Amps > Mods & Tweeks
Old 10-17-2009, 11:48 PM   #1
LTP vs. Cathodyne for 6L6 tweed
Hi,
i'm on a 5E5-A Tweed Clone and I like it very much.
The Power Tubes clipps first and smooth but driven harder the
cathodyne PI gives some raw and fuzzy distortion.
Do you think a conversion to Long tailed pair PI could work for me ?
Is there a different sound from different PI 's ?
Thanks
ben-horn is offline   Reply With Quote
Old 10-18-2009, 01:37 AM   #2
Supporting Member
loudthud's Avatar
Try an experimental mod I posted in reply #3 of this thread:
Paul C mod for PR
The self-biased concertina PI doesn't always bias at the optimum point. The mod allows you to easily set the bias point and also allows you to try different tube types. Does your presence control adjust as expected? Some other builders have had less than expected results.
__________________
WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personel.
loudthud is online now   Reply With Quote
Old 10-18-2009, 10:01 AM   #3
thanks loudthud
Yes, the presence works very subtle but I expect this cause of very low nfb.
I already did the Paul C Mod with higher Bias Resistors. 3M9 into 1M was the best for me.With 4M7 into 1M the cutoff was very raw sounding while 3M3 into 1M reduced the headroom too much. Would you tell me your impressions about the sound differences of LTP vs. cathodyne ?
Thanks
Old 10-18-2009, 12:21 PM   #4
You might try Merlin's grid current limiting approaches from his site and book.
The LTP will drive the power amp harder than the concertina. I haven't tried switching back and forth in an amp between the two, but I do know the LTP drives the power tubes harder. A paraphase will also. They both have more swing than the cathodyne.
Greg
soundmasterg is offline   Reply With Quote
LTP vs See Saw Smitty Theory & Design 3 06-16-2009 05:55 PM
Buffered cathodyne vs. LTP octal Theory & Design 13 04-03-2009 11:49 AM
Humming cathodyne splitter crholguin Maintenance, Troubleshooting & Repair 14 02-19-2009 12:41 PM
Tweed Deluxe 6l6 OT options haricros 5 E 3 13 11-22-2008 08:03 PM
gain differences in driver/PI stages for cathodyne, paraphrase, long tail pair tubeswell Tweed Builders 5 03-23-2008 10:28 PM
