Go Back   Music Electronics Forum > Schematic Requests
Old 10-18-2009, 12:00 AM   #1
Dave Curtis, dB AudioTech's Avatar
Kustom TRB400 schematic?
Would be greatly appreciated.
Dave Curtis, dB AudioTech is offline   Reply With Quote
Old 10-18-2009, 12:39 AM   #2
What are the board numbers?
is this an old product, or is this contemporary Kustom product?
__________________
Old 10-18-2009, 08:49 AM   #3
Hi Enzo,
Thanks for the quick reply.
It's fairly recent. Made in China.
The solder side of the preamp board says:
Kustom Music Inc.
Copyright 2KYEAR
TR400B
Preamp bd
On the rear jack board:
280-120400-110
Power board:
280-120400-120
Loud buzz. Diodes on the power bd checkout OK; R314 & 337 are burnt. I haven't pulled it apart, yet.
Old 10-20-2009, 01:21 AM   #4
Not familiar with the unit, but burnt resistors and loud buzz - look for DC on the speaker - sounds like shorted output transistors offhand.
My fairly extensive Kustom file covers the old stuff, not the recent stuff. But have you contacted Kustom and asked for the info?
__________________
Old 10-20-2009, 12:28 PM   #5
Thanks, Enzo. Yes, Mark Sharp from Kustom sent me them yesterday, along with an offer to become one of their service centers (I'll have to mull that one over; I'm already too busy). I haven't checked for DC on the output, but I did check the outputs for shorts, which came up negative. I still haven't pulled the PA assembly; I have to get the "cutting-out Crate" done first.
Old 10-28-2009, 01:47 PM   #6
Still heating up
Any I idea why these 2 resistors are heating up (R314 & 337; upper left on p3)? I've replaced them with 1/2W parts. There's no buzz now, and and the amp works, but these 4.7K are getting very hot. It looks to be part of that Vactrol circuit (mute?). I'll post some voltage measurements L8R... (IIRC, 70-something at the top of R314)
Thanks,
Dave
Old 10-29-2009, 02:19 AM   #7
I have no idea, those along with 317 and 318 are in series across +V and -V. They seem to be setting some thresholds for the limiter opto. I think...
Check your zobel at the power amp output. COnceivably if the amp was unstable and oscillation above hearing, a ton of signal could be coning through those diodes... Nah, I am not happy with where that theory is leading.
Whatever is +V and -V, calculate Ohms Law what those resistors have to dissipate and see if the original part wattage was sufficient. At 70v, I get about .6 watts. Of course I haven;t had my dinner yet.
__________________
Old 10-30-2009, 01:28 AM   #8
Quote:
Check your zobel at the power amp output. Conceivably if the amp was unstable and oscillation above hearing, a ton of signal could be coming through those diodes... Nah, I am not happy with where that theory is leading.
I haven't scoped it yet... Been pulling long hours at the day job.
I measure 117V from the top of R314 to the bottom of R337, for about a 1.5W; the OEM parts were cooking at .75W each. 317 & 318 both have about 20V, putting them near their .25W limit.
Old 11-05-2009, 11:59 PM   #9
Update on the hot resistors:
A tech at Kustom advised replacing the 4.7K resistors with 1 watt parts. I'll be doing the 1.5K resistors also.
Kustom 200 schematic Twist Schematic Requests 15 08-05-2009 12:29 AM
Kustom Kasino Club schematic(s) needed Euthymia Schematic Requests 3 04-08-2009 04:57 AM
Kustom KMA30 Schematic MurrayT Music Electronics 3 07-02-2008 05:46 AM
Kustom amp schematic Virg Guitar Amps 0 06-09-2008 04:55 PM
Kustom K100 2 Schematic cjlectronics Maintenance, Troubleshooting & Repair 10 01-16-2008 02:14 AM
