| | #1 |
| Member Join Date: Jan 2008 Location: Richmond
| Toggle Switch Brands?
Searching didn't turn up any discussions about different toggle switch manufacturers. We all know Carling. I did see some reference to NKK. Has anyone used/seen a Mountain toggle switch? I'm looking for a single-pole/triple throw on/off/on toggle switch for the front panel. It will be switching different cathode bypass caps (and maybe resistors) on a 12AX7 triode. What do you all think about this? 1055-TA2130-EVX Mountain Switch Toggle Switches It's less than 1/2 the cost of the Carling alternative. Thanks for your thoughts, Chip |
| | #2 |
| Senior Member Join Date: Dec 2006 Location: York Pa
I use Mountain and C&K regularly for front panel tone options and have not experienced anything negative from either brand.
__________________ -Mike |
| The Following User Says Thank You to defaced For This Useful Post: | TheTinMan (10-19-2009) |
| | #3 |
| Junior Member Join Date: Jan 2009
I've had Mountain switches come apart in my hand after only a few cycles of operation. Go know. Komet uses those NKK switches. In the same configuration a batch of 10 I found differences in the force required to throw the switch. So NKK aren't bad but they're not consistant if that's a concern. I've always liked Carling until the last few years since they've gone to Mexico for assembly. The stompbox standard DPDT has turned to useless garbage even though they sell for $14+ USD. C&K and Alcoswitch provide a decent product in mini toggle switches which are quite affordable. Grayhill is exceptional when price is no object. But the previous two brands are what I use any more. I can't bring myself to skimp on switches anymore than I can use crappy pots on an amp build. PEC 2 watt pots, period. There are only a few mechanical parts in an amp so why not eliminate the chance for failure in the components the user is most likely ever to confront? I build amps for musicians but realize they can be complete gorillas and design for this inevitability. YMMV, Noel Grassy. |
| | #4 |
| Junior Member Join Date: Mar 2008 Location: Finland
I've used lots of different brands over the years. I would add also Bulgin and Marquardt to the no harm-list. -T |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Fender Champion 600 On/off toggle switch | Parktreeone | Maintenance, Troubleshooting & Repair | 9 | 05-03-2009 03:18 AM |
| valve brands for fender amps? | tomfarnan | Maintenance, Troubleshooting & Repair | 1 | 04-05-2009 01:01 AM |
| mesa boogie toggle switch replacements | PRNDL | Maintenance, Troubleshooting & Repair | 4 | 03-07-2009 11:05 PM |
| First post: help need with master tone toggle, master SPC toggle (strat) | blake375 | Guitar Tech | 1 | 10-17-2008 05:35 PM |
| Mixing brands of output tubes | GlennW | Maintenance, Troubleshooting & Repair | 12 | 05-05-2007 08:51 PM |
