| | #1 |
| Member Join Date: Mar 2008
| Tele- 1 cap per pickup
Is there a way to wire the standard tele setup to have one tone cap value for the neck pickup and a second value for the bridge pickup? In other words, when I select the neck pickup, I'd like to use a .012uF cap, but a .047uF on the bridge. I'm thinking I might have to wire caps in series and use the selector switch to strategically split them. This may help out in the middle position. Any suggestions? It's either this or no load pot that I only turn to "10" (off) while using the neck pickup. |
| | #2 |
| Junior Member Join Date: Sep 2009 Location: Scotland
Use the one side of the switch for pickup switching, use the other side to select which tone control cap gets connected to the tone control in each position.
| | #3 |
| Supporting Member Join Date: Jun 2008 Location: Italy
Hi, I would change the tone pot to a "500 K linear" one ( with center "click" ) soldering the "master tone" wire to the pot's center lug, then soldering the two different tone capacitors between the pot's outer lugs and GND ( pot's body ). This way, with the pot centered you have an "open" tone circuit, ( just like the old tone pot set to "10" ) then, by rotating the pot CW or CCW you get two different "behaviors" out of the tone pot - Being the STD Tele tone control a "master tone", it will work with both pickups. I found this mod here on the forum, though I can't remember who posted it...sorry! This solution is simple and effective IMHO, and does require neither a major rewiring nor adding switches/holes. Hope this helps Best regards Bob
__________________ Foolproof equipment is hard to design, because fools are VERY ingenious... |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Tele pickup in a humbucker hole? | TigerG | Guitar Tech | 4 | 03-06-2008 11:48 PM |
| anyone want a 59' tele pickup | truetone | Pickup Makers | 18 | 04-25-2007 09:53 AM |
| Best pickup for vintage Tele | RickyD | Pickup Makers | 28 | 04-19-2007 07:45 PM |
| Tele tone control cap question | Regis | Guitar Tech | 3 | 04-17-2007 09:56 PM |
| '68 tele pickup | Als Kimp Tones | Pickup Makers | 4 | 12-21-2006 06:19 AM |
