Go Back   Music Electronics Forum > Music Electronics
Music Electronics General discussion about music electronics
Old 10-22-2009, 08:55 PM   #1
Vox AC 30CC2X problem
I have a stock vox AC30cc2x. I haven't played it for about 6 months. Turned it on and the rectifier got powder, but nothing else. Swapped all tubes and checked connections but nothing. Any help out there?
es335man is offline   Reply With Quote
Old 10-22-2009, 11:03 PM   #2
If the heaters are not glowing in all the other tubes, then chances are you have a blown fuse inside. FS2 is a 6.3 amp slow blow fuse that serves the heaters. it may be simply blown from fatigue, or there could be a problem. if a new fuse blows, then something is wrong, possibly a bad power tube.
__________________
Old 10-22-2009, 11:04 PM   #3
vox ac30's
Welcome to the show.....
Now have you checked the ht fuse?
Just moving tubes about will not make it work, ok so you say you've checked inside connections and still no o/p. Have you gave the pcb the once over for dry solder joints or cracks in the print?
Do you have the diagram to aid with voltage and signal tracing.
amptech is offline   Reply With Quote
Old 10-22-2009, 11:12 PM   #4
vox ac 30
I would tented to go with on enzo on this one has he's advice come's from over 40yrs in this feild..
Vox DA15 problem Ezro Maintenance, Troubleshooting & Repair 8 09-28-2009 11:13 PM
Vox AC30TB gain problem rf7 Maintenance, Troubleshooting & Repair 3 04-11-2009 07:03 AM
Vox 847a problem murphcc1 Guitar Effects 1 04-04-2009 02:32 AM
vox heritage ac30 problem thenorm Guitar Amps 3 12-27-2008 06:44 PM
Vox AC-15 Problem Pablomago Maintenance, Troubleshooting & Repair 2 09-16-2008 11:39 PM
