Go Back   Music Electronics Forum > Instrumentation > Guitar Tech
Old 10-23-2009, 11:42 PM   #1
coil tap
i bought emg h1a humbucking passive pickups, and i would like to wire them so that i have 1 tone 1 volume, 3way switch, and that the tone pot is a push/pull so that i can coil tap it.
can i do that?
wiring schematic?
josh_homme is offline   Reply With Quote
Old 10-24-2009, 06:12 PM   #2
Pickup Maker
David Schwab's Avatar
Quote:
can i do that?
wiring schematic?
EMG uses the same color codes as DiMarzio, so you can use this as a guide:
Free information : DiMarzio Humbucking Pickups at Stewart-MacDonald
Yu want the "coil cut" switch. "Tapping" is something different.
Here's the EMG instructions, but they don't tell how to switch the pickup to single coil:
http://www.emginc.com/content/wiring...MGHZ-H1-H4.pdf
All you have to do is switch the black/white wires to either ground or hot, depending on which coil you want to cut.
David Schwab is offline   Reply With Quote
no HV center tap stingray_65 Theory & Design 8 03-10-2009 06:31 AM
Transformers - What to do with spare tap? cat Build Your Amp 2 09-23-2008 08:51 AM
stop a single coil, add a tap - keep winding - no workie! pupoholic Pickup Makers 8 01-03-2008 02:11 PM
What part of the coil to tap? Mark Hammer Pickup Makers 19 12-18-2007 05:55 PM
Fine tuning strat single coil pups with a dummy coil? Silent Bob Pickup Makers 0 11-04-2007 07:15 AM
