Go Back   Music Electronics Forum > Amplification > Other Amps
Old 10-23-2009, 10:48 PM   #1
peavey xr600b buzzing
I just got a peavey xr600b today and it buzzes much like a shorted guitar cable sounds. The mixer section works fine when ran into an amplifier through the front but when I plug a speaker into the speaker jack it buzzes at the same volume regardless of volume settings and the compression light stays on. I tried different cables and different speakers. Fuse is correct and good. Any help appreciated.
checkedgoldtop is offline   Reply With Quote
Old 10-24-2009, 12:40 AM   #2
Is there DC voltage across the speaker output? A simple method is to plug a cord into the amp output jack, and measure for voltage at the other end of the cord.
Most likely either the output section is blown putting DC on the speaker - loud hum. Or you have lost one of your main filter caps - loud hum.
__________________
Old 10-26-2009, 08:49 PM   #3
Thanks Enzo, how do I set up my meter? I am not too savvy, I got ac and dc but the sky could be brown for all I know.
Old 10-27-2009, 03:24 AM   #4
You are looking for DC voltage - and hoping to find none.
__________________
Old 10-27-2009, 09:05 PM   #5
I set the meter at 1000 DCV and got fluctuation between -.4 and 38. I also set to 200 ACV and got fluctuation between 41 and 98.
Old 10-28-2009, 12:59 AM   #6
Looks like you might not be getting good contact between your meter probe tips and the test points you are using.
If you are getting 38VDC on the output, then something serious is wrong in there. If you are really mnot getting DC but lots of AC, then I would be looking at either a bad main filter cap or broken solder to one of the main filter caps.
__________________
Old 10-28-2009, 01:47 AM   #7
Would a transformer swap be a possible place to start? Then caps? Money pit? I tried a different cable, tried unscrewing the end and going directly to the cable wire, pushed hard, still fluctuation.
Old 10-28-2009, 04:23 AM   #8
Transformers are the LEAST likely thing to fail in an amp, yet everyone puts them at the top of the list.
I would measure DC voltage right at the main caps and see if that is stable. And I realize I am probably leaving you behind here, but I would get out my scope and see what was going on in the circuit.
__________________
Old 10-29-2009, 08:46 PM   #9
I tested at the 2 capacitors (long d battery sized metal tubes?) and got fluctuation from one but not the other.
Old 10-30-2009, 01:09 AM   #10
The whole purpose of those two large filter caps is to provide smooth even DC power. ANy one that doesn;t is suspect.
__________________
Old 11-02-2009, 10:19 PM   #11
Where do I find those? I have been searching but no luck.
Old 11-03-2009, 12:43 AM   #12
You can always order Peavey parts right from PV.
If you are looking for 5000uf 55v caps, you won;t find them. They were a custom part and not standard value. You can find plenty of the 4700uf 63v caps as standard values. That is what PV sends out in their place. You may have to carefully drill a hole or two for the leads of the new cap to fit ionto the board. If your caps are mounted by themselves in the cabinet, then the leads don;t matter.
__________________
Old 11-06-2009, 12:25 AM   #13
I really appreciate all of your help so far I am getting an education for sure. Do I have to change both caps, or just the suspect one?
Old 11-06-2009, 01:19 AM   #14
I myself would replace the bad one to see if it solved my problem. I would then go back and replace the other one if I felt the amp needed fresh parts. My personal philosophy is to finish the repairs before doing any mods or upgrades.
__________________
Peavey xr600b distorted output Alan Other Amps 20 10-20-2009 12:37 AM
Peavey XR600B (400BH) Wendell Music Electronics 2 05-22-2009 12:59 AM
Peavey XR600B no sound dentsinger Music Electronics 20 08-23-2008 04:03 AM
Peavey xr600b clipping Kip H Music Electronics 19 08-16-2008 12:48 AM
Help with Peavey XR600B rizingtide Maintenance, Troubleshooting & Repair 5 02-11-2008 07:36 PM
