Go Back   Music Electronics Forum > Amplification > Guitar Amps > Theory & Design
Old 10-23-2009, 11:03 PM   #1
higher voltage on OT than originally called for
On my Bogen chb-35a, the way I have it set up right now I have 490v on the OT.. Originally the schematics show 460v as being the source for this.. Is it likely that I'm going to burn it out quickly doing this?
thehoj is offline   Reply With Quote
Old 10-24-2009, 12:04 AM   #2
Old Tele man's Avatar
...depends on how old the tranny is. It used to be pretty much standard engineering practice for PT's and OT's to be sized 50% over normal use requirements.
...the problem is that way back then, the paper interleaving between the windings and winding coatings were probably at least 150%, but over the intervening years things have dried out and become brittle, so that extra 50% of reserve rating might NOT really be there today.
...that said, I'd guess only +30V probably won't hurt, but we really have no way of knowing...until something fails, then, you know.
__________________
Old Tele man is offline   Reply With Quote
Old 10-24-2009, 12:21 AM   #3
Just trying to get a feel for what kind of thresholds these old transformers might have.
Is there anywhere to get specs on the tranny's for these bogens? I have no idea what kind of replacement I would even get if this thing went.
Old 10-24-2009, 12:22 AM   #4
olddawg's Avatar
If the problem is that the B+ is too high you can always lower it a bit with a couple of 10v 5watt zener diodes in series. Three of them would reduce your B+ by 30v. It's done all of the time and the zeners are only a couple of dollars. You can even switch them in and out. Just mount them where thay can breath a little.
olddawg is offline   Reply With Quote
Old 10-24-2009, 12:48 AM   #5
It is not even a 10% variation. I wouldn't worry about it.
__________________
Old 10-24-2009, 05:40 AM   #6
Supporting Member
I'm with Enzo on this one...old Fender amps' schematics called for a 20% tolerance on voltage measurements, and many of them worked very hard through the years and managed to survive....
This said....and just because I'm curious, have you checked what your mains voltage is? If the amp was designed with, say, 110 VAC in mind ( don't know which side of the pond you are on ) and your mains voltage is, say, 120 VAC, that would explain the phenomenon.
Cheers
Bob
__________________
Foolproof equipment is hard to design, because fools are VERY ingenious...
Robert M. Martinelli is offline   Reply With Quote
Heyboer 22772 PT originally intended for a 5c1 Edgar Sterling Tweed Builders 0 08-09-2009 10:20 PM
How long do we have to put up with being called "Junior"?! Mark Lavelle Lobby 44 04-27-2009 11:24 PM
Higher PT voltage or different Rectifier? Ringwraith Tweed Builders 4 03-12-2009 02:25 PM
voltage on G2 higher than A on el34's? black_labb Theory & Design 13 11-11-2008 03:06 PM
Plate voltage and OT impedence of the 5E3? Satamax 5 E 3 0 07-03-2006 11:33 PM
