| | #1 |
| Junior Member Join Date: Oct 2009
| Magnatone M9 running a 2x12 cab....
I have a magnatone M9 that I want to use to run a 2x12 cab with the internal speakers disconnected. The M9 has a 16 ohm 15" oxford speaker and an 8 ohm 4" speaker. Should I load the 2x12 cab with a 16 AND an 8 ohm speaker? I've attached the schematic if that helps....
| | #2 |
| Senior Member Join Date: Aug 2008 Location: Phoenix
The 8 ohm speaker has a 4uf cap in series. This will block(Roll Off) bass to that speaker. Thus, it's actual effect will be less than a direct connected 8 ohm speaker. You should use two 8 ohm speakers in series for a total of 16 ohms which is the same as the transformer driving the speakers.
| | #3 |
Thanks!
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Help with Fender 2x12 Cab Identification - I think it's a 1963 or 1964... | VictoryNVH | Vintage Amps | 4 | 02-17-2009 08:14 PM |
| 2x12 Cab or Head for Mission FE3? | NeedToKnowBassist | 5 E 3 | 1 | 08-23-2008 04:48 PM |
| FS: CUSTOM WALNUT CAB 2x12 | msoftich | Flea Market | 0 | 06-29-2008 04:39 AM |
| 2X12 Cab, need help | CattMallahan | Build Your Amp | 1 | 05-23-2008 03:38 AM |
| newbie needs to make a new cab for a 2x12 blues deville | 31trum | Cabinetry | 4 | 07-06-2006 05:39 PM |
