| | #1 |
| Junior Member Join Date: Oct 2009
| Identify Color code for OT push pull.
Good people, I was wondering if I may ask for help indentifing the wires of this OT I picked up. It is from a Pioneer stereo receiver from the 60's. Two OTs inside with four EL84 and a massive PT. The wires were cut, so I am a bite loss. This is new territory for me. Need a little help to get started. Thanks in advance.
| | #2 | |
| Senior Member Join Date: Apr 2008 Location: PDX
| Quote:
Integrated Publishing - Educational Training Manuals Output Transformer Impedance http://www.tech-systems-labs.com/pdf...nformation.pdf http://www.radiodaze.com/catalog-306-colorcode.pdf Vintage Radio Troubleshooter's Handbook CD Notes On Servicing Radio And Sound Equipment | |
| | #3 |
| Old Timer Join Date: May 2006 Location: NYC
On the primary side,the 3 wire,the red is your CT the other 2 connect to the plates of the power tubes.On the side with the 4 wires one is going to be the ground connection.The green and yellow are likely speaker "hot" connections,possibly 4 and 8 ohm,so that leaves the white and I cant tell what color the other one is,as your ground connection.You would have to measure the resistance from one of these to the other 3 to determine which is the ground.You will have to determine the turns ratio so I would go straight to that test to sort things out.To do this you need to connect a signal generator or a variac to the primary outside wires.I cant tell the colors but these would be the 2 that arent the red one.Put a half volt ac on these two and then measure the ac voltage at the secondary connections using either the white or the other one as the ground and post back with the results and we can sort it out from there and I will explain how to get the turns ratio and which connection is the 4,8, and 16 ohm connections,assuming that is what they are.Could 2,4 and 8 ohm or something,but we'll cross that bridge when we get there.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Push-pull OT for 12AT7 | GibsonLover | Theory & Design | 12 | 03-10-2009 08:00 PM |
| Hammond 1750N OT color code? | daz | Theory & Design | 1 | 08-06-2008 04:10 AM |
| Handy On-line Resistor Color Code Calculator | bob p | Build Your Amp | 3 | 10-25-2007 03:06 AM |
| Heyboer color code | daz | Maintenance, Troubleshooting & Repair | 4 | 03-02-2007 07:31 AM |
| Question about unequal OT primaries and push-pull | Matt T. | Theory & Design | 7 | 01-25-2007 02:55 PM |
